Author Topic: Gti Pioneer Head unit  (Read 1235 times)
Offline Trav Turbo
  • -Given: 18
« on: June 21, 2018, 08:57:04 pm »
Hi all I've been just bought a new Pioneer Double Din head unit to replace my old Pioneer. It all works well but whenever I turn the key it resets itself and loses whatever I had on previously. I've swapped the red & yellow wires around and still resets itself. I've heard I need to run a separate power supply for it, I'm presuming  a fuse tap is what I need.
Has anyone had this problem before and sorted it?
Or is there a guide available to run a separate power supply to do it?
Thanks.
Sent from my SM-N910F using Tapatalk
Offline neilw
Re: Gti Pioneer Head unit
« Reply #1 on: June 22, 2018, 11:44:48 am »
Do you have any kind of harness adapter installed? I think the standard on/off signal comes from the Canbus, which may be confusing it.
What facia adapter have you used? as I'm probably going to replace mine at some point.
Edition30 #0002 R-Tech Stage2
Offline Trav Turbo
  • -Given: 18
« Reply #2 on: June 23, 2018, 11:14:36 pm »
No canbus just plug and play with mine, only had to change facia to fit it. I'll look into it but haven't heard of people using canbus to fit aftermarket stereos, I didn't use one on my previous Pioneer stereo in my car which I had for few years.
