Author Topic: Sensor on the thermostat housing ???  (Read 1078 times)
Colinspence
« on: June 28, 2018, 08:09:20 pm »
So I’m trying to get the fans working
On my 2.0 tdi 140
Iv replaces the fans ..
Going to replace the thermostat
And Iv found a sensor that plugs into the housing ...
Is this another temp sensor (exactly the same as the coolent gauge sensor )??
As I can’t find a name for it anywhere not even in the Haynes Manual and I want a new one so make sure I can sort this none fan working problem out when it’s up to temp
Offline Tazocin
Re: Sensor on the thermostat housing ???
« Reply #1 on: June 28, 2018, 09:02:46 pm »
Yes. 2 sensors, on my car, one on the main thermostat housing and one near the inline stat above my dsg. Both are grey and held in with plastic u clips
Colinspence
« Reply #2 on: June 28, 2018, 09:04:38 pm »
Thanks.
So I’ll order the same sensor again and hope it finally works.
Colinspence
« Reply #3 on: July 01, 2018, 01:55:48 pm »
Iv changed the sensor. And the thermostat but still the fans won’t come on when up the temp ?
Is there a fan relay or a fuse ??
Iv checked all the fuses and can’t see any blown
 :thinking:
Colinspence
« Reply #4 on: July 01, 2018, 08:47:49 pm »
Finally sorted it after blood sweat and tears  :drinking:
It just jumped into life after a drive
