Author Topic: Monza 2 valves, advice  (Read 1257 times)
Offline Tattooroo
« on: July 01, 2018, 08:21:58 pm »
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F323311252237
Hi I need 2 new valves for my bbs monza hollowbacks 2 18s vw want silly money, are these one on eBay the same. 8mm 42mm long.
Thank you
Re: Monza 2 valves, advice
« Reply #1 on: July 01, 2018, 10:43:00 pm »
To me the originals look different as it was a bespoke design and only available from VW.
How much are VW wanting for a new one now?
Offline Octoparrot
  • -Receive: 102
« Reply #2 on: July 01, 2018, 10:47:21 pm »
I'm not sure they'll fit, I found with aftermarket valves the threaded portion that sticks into the inside of the wheel isn't long enough so the other bit the holds the valve in place can't pick up on the thread, unfortunately I think you'll have the stump up for ones from VW, I tried searching for alternative sources but had to admit defeat in the end, luckily I got a set of the later wheels that use the normal rubber valves.
Offline Tattooroo
« Reply #3 on: July 02, 2018, 06:33:02 am »
Ah thank you, thought because these were bbs ones that they'd fit.
Local vw want £21+vat each, so £16 for 4 would have been a saving.
The only info I could find on the monza ones was 8x46mm
Thank you
4ndy
« Reply #4 on: July 02, 2018, 06:36:32 am »
message the seller. Hes a vw tech so should be able to help :happy2: :happy2:
Offline Tattooroo
« Reply #5 on: July 02, 2018, 08:18:00 pm »
I messaged and he said he's sold both the 11mm and 8mm to owners of monzas so wasn't much clearer.
Can they not be overhauled at all, new seals fitted?
« Reply #6 on: July 04, 2018, 10:25:51 pm »
Check your message inbox as I found out notifications of new received messages isn't working correctly.
