Author Topic: Revo stage 1..clutch slipping :(  (Read 1657 times)
Offline steve D
« on: February 11, 2010, 04:57:00 pm »
Ok so i've just picked my ED30 up after its had the revo stage 1 and when set on setting C my clutch is slipping under full load mainly in 4,5 and 6th gear and a one point the EM light came on!!!  :sad1:
Anyone else have this problem?
I cant believe its slipping just after stage 1! the oem clutch must be sh*te!!
Whats a recommended upgrade?
Back to standard!!!!
Re: Revo stage 1..clutch slipping :(
« Reply #1 on: February 11, 2010, 04:59:01 pm »
whats the setting?
Offline steve D
« Reply #2 on: February 11, 2010, 05:07:09 pm »
Not got a clue  :confused:
He never said anything about settings! Just  the 3 different maps A B C.
I take it i'll need to find out, he was rushed of his feet so didnt really get chance to ask as such.
« Reply #3 on: February 11, 2010, 05:08:26 pm »
did u get the switch then and the software ? if so plug it into your laptop and see what the settings are
Offline GTIjames
« Reply #4 on: February 11, 2010, 05:17:14 pm »
i wouldnt bother playing with the settings unless you got vagcom to see how the car is performing
too much timing and boost for your mods/fuel will cause the car to pull back = loss of performance
if you have the sps switch plug it in to your lap top and check what settings you are running - i never had revo stage 1 so not sure what the best settings are but Im sure someone on here can help
 http://www.revotechnik.com/products/pdf/SPS3_advancedUserGuide060406.pdf
« Last Edit: February 11, 2010, 05:18:52 pm by GTIjames »
Offline subaru26675
« Reply #5 on: February 11, 2010, 05:27:08 pm »
Yep, sounds familiar, very familiar  :sad1:
Mine did the same after revo stg 1.  car has 18K miles and has just been fitted with a new DMF and clutch, all good now though  :jumpmove:
My revo was in for just over a month when the dmf gave up, not the first person to happen to and certainly wont be the last.
Kev.
Offline steve D
« Reply #6 on: February 11, 2010, 08:34:58 pm »
All i was given was the select switch, i've put it on setting A and the clutch is still slipping  :confused:
I'm very suprised tbh and was'nt expected that to happen so soon, i could understand if i was lauching the car etc
Looks like a uprated clutch is needed then,think VW must use chocolate to make theres.
Offline micky 32
« Reply #7 on: February 11, 2010, 09:40:01 pm »
You will find cold weather won't help, if it warms up it might disappear. I have the equivalent to stage 2+ on the KO4's and in this cold wetaher it slips at 5500 to 6000 rpm! It's not the torque that's slipping mine it's the bhp :scared:. I'm going to get a nice Sach uprated one, had one on my TDI great clutch.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
