Author Topic: Airbag warning light diagnostic  (Read 1235 times)
Offline Mickymurf
« on: July 08, 2018, 09:57:11 pm »
Hi guys I’ve the airbag warning light on my 2006 golf gti, can anyone recommend someone/company in the manchester/northwest area who could 1 diagnose and 2 fix it for reasonable money?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Airbag warning light diagnostic
« Reply #1 on: July 09, 2018, 10:24:46 pm »
It's normally just some wiring bad connection, from the airbag itself to the CAN gateway. An auto electrician should be able to find the issue. I think most of the times the problem is just in the plug under the seat.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: July 10, 2018, 08:10:58 am »
Anyone with a £5 bluetooth or a £15 china VCDS cable can give you a fault code and attempt clearing the fault code
As for cost - could be a 10 minute wiring fix as mentioned, or the airbag/igniter could be goosed and new parts will be many hundreds to replace. Find someone nearby to read the fault codes for you and go from there
Offline neilw
Edition30 #0002 R-Tech Stage2
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
