Author Topic: My Edition 30  (Read 15129 times)
Offline GTIjames
Re: My Edition 30
« Reply #30 on: January 13, 2009, 10:57:52 pm »
thanks for all the advice, if i knew that bit fitted a few weeks ago when i first had the bits put on, then i might not have been so disappointed with the evoms cover on its own. and would have also clipped on last weekend when I was at me ma's.
anyhow shows the benefits of thes forums   :grouphug:
overall though really happy with how car is running now.
vf engine mounts - one of my favourite mod's, quite alot of vibrations and extra cabin noise first few hundres miles but now really settled in and hardly noticeable, once used to them, but everything seems improved - feel of car, accelerating, breaking, cornering and gear changes, i also dont get wheel hop anymore when the car judders when flooring it i just get wheel spin now  :evilgrin:
coilovers - really loosened up lately and grip is very good, and gives you alot more confidence in the corners. though quite a low ride and speed humps in london are sometimes an issue - may raise it a bit soon  :sad:
blufin stage 2 map  is running very well, im not one to use the accelerating pedal conservatively or progressively , am 25 with 324bhp going through the front wheels of my gti.. whats a boy to do. but no engine light problems for me and is running better than ever with this cold weather especially when you get a nice dry road.
Re: My Edition 30
« Reply #31 on: January 18, 2009, 11:00:09 am »
The Evoms engine cover was designed to use the silver centre section of the original oem cover,
which is why I asked if you were going to fit it, as it makes the cover look a hundred times better.
like this:
:innocent:
....You beat me to it, Matt!
Regal :fighting: really should have told you that, James - They're meant to be the UK representatives of EVOMS.
Apart from aesthetically tidying up the messy appearance of the 2.0T FSI engine, a cover will give a wee bit more protection from the elements - Just look how splashed etc an oem cover can get.
Personally, I like the EVOMS cover a lot and think it looks very purposeful.
It looks even better with a carbon centre strip :evilgrin:
Great feedback and info on the engine mounts, James :happy2:
It's my next mod, but VWR's 'Fast Road' version (as opposed to their hardcore race version).
Cheers! :smiley:
« Last Edit: January 18, 2009, 11:01:55 am by RedRobin »
Re: My Edition 30
« Reply #32 on: January 21, 2009, 05:57:31 pm »
Came across another pic for you, James : -
Offline GTIjames
Re: My Edition 30
« Reply #33 on: January 29, 2009, 11:22:47 pm »
thanks for the pics robin, I was at me ma's last weekend and tried to fit the silver cover to the evoms, though was not so easy,oem silver cover has clips all the way up, 4 of them so you have to cut these off, now the question is what glue is best to use which won't fail with the engine heat?
Any help would be great
J
Re: My Edition 30
« Reply #34 on: January 30, 2009, 12:34:16 am »
Those very strong sticky pads? My number plate is stuck on with them [Wolverhampton-proof, I hope!]
I got mine from Ant Graphics in Bedford via TTshop. But will they stick to metal?
Offline GTIjames
Re: My Edition 30
« Reply #35 on: March 09, 2009, 11:48:24 am »
Few updates to the car done recently and some more planned for later in the week.
First off finally got the new brakes fitted, had a small issue when fitting in that they needed a 8mm spacer to clear the 18" pescara wheel. the spacers they used were cheapo ones and left the ride feeling terrible so Wheelman kindly provided us with 10mm hubcentric ones, decided to get all 4 wheels done so it looked right and now ride is back to normal. Brakes now bedded in and feeling very positive and alot firmer than stock one's in all situations.
all 4 wheels now with 10mm spacers
Had the APR high pressure fuel pump fitted too the same day and this has already had a noticeable improvement on mid range pull without having a new remap, but off to Superchips this friday to be re-tuned to take the pump in to account and they can turn up the fuel pressure to 130 bar  :evilgrin: - RESULTS of this to come..
also the new oem 'd' dv valve was put in, i know there has been some issues regarding whether this is the correct part for the tfsi, but so far fitted well and car has been running like normal can't tell if there has been any noticeable improvements as this seems to have come from the fuel pump.
Will update after Friday with the results of the re-tune with superchips.
Offline WhiteGTI
  • F-A-S-T
Re: My Edition 30
« Reply #36 on: March 09, 2009, 11:50:48 am »
Sounds good James!
This car should be a serious weapon at the Pod if you make it on Saturday!!!
2006 E46 BMW M3 - 343hp
Offline SteveS
Re: My Edition 30
« Reply #37 on: March 09, 2009, 11:52:17 am »
looks like it need a REALLY good polish!! :nerd:
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Re: My Edition 30
« Reply #38 on: March 09, 2009, 11:56:17 am »
Keep us posted matey. Looking forward to see the results from Superchips  :happy2:
Offline CarrG
Re: My Edition 30
« Reply #39 on: March 09, 2009, 12:47:02 pm »
Looks a great list of mods. Be interested in the power and torque curve with the map adjusted to suit new pump.  :happy2:
K1 Revo 2+
Ibis RS3
Offline GTIjames
Re: My Edition 30
« Reply #40 on: March 09, 2009, 12:57:04 pm »
it certainly does, but i prefer driving it than cleaning and polishing it
but i have just purchased a Meguiars Quick clay kit and Werkstat Acrylic kit so when i get a spare few hours on the weekend it will be looking nice and shiny.  :happy2:
Offline cal tdi
  • dub or die
Re: My Edition 30
« Reply #41 on: March 09, 2009, 08:59:44 pm »
as a self confessed brake whore yours looks  :drool: :drool: :drool: :party:
top car  :happy2:
Candy weiß Mk6 GTI - Stage 2
Offline GTIjames
Re: My Edition 30
« Reply #42 on: July 07, 2010, 12:34:31 pm »
thought I might update the build thread....
well I finally got it back last friday after been without it for 3 months or so, has been repaired from this:
to this  :smiley:
pleased with how its looking, although there are still a few errors popping up so will be going back unfortunately as I think the exhaust has gone as its making an unusual sound and the mil light is on, also got an error code for the power steering..
apart from that though it drove pretty well, dsg wasn't changed unfortunately but seems perfect.. boost is strong, handling is pretty sharp but im getting vibrations through the steering wheel when doing three figures so that needs looking at too
but good to have it back and driving again  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: My Edition 30
« Reply #43 on: July 07, 2010, 12:39:41 pm »
good to see you back in the GTI  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Re: My Edition 30
« Reply #44 on: July 07, 2010, 12:46:06 pm »
 :congrats: :driver: :driver:
