Author Topic: Golf Gti MK5 DSG Fuel Cut/ Loss of Power  (Read 3412 times)
w4qas321
« on: July 24, 2018, 10:02:29 pm »
Hi All,
Having a few issues with my GTI DSG cutting fuel/ loss of power at the moment  :sad1: started getting these problems ever since i bought the car... when cruising on the motorway it decides sometimes to drop to 4th gear and cut all fuel and has a loss of power and will return back to normal however sometimes it needs to be turned on and off to return back to normal. I have changed the done the below and still has not change:
1 - Low Pressure Fuel Pump
2 - High Pressure Fuel Pump
3 - Cam Follower
4 - Had a Stage 1 Map took the car back to normal and still the same
5 - Spark Plugs
6 - Fuel Filter
7 - DV
8 - Fuel Pressure Sensor
9 - Fuel Pressure Valve
and the car still does the same and i have ran out of options??
Offline Raj2212
  • -Given: 75
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115142.0.html
Re: Golf Gti MK5 DSG Fuel Cut/ Loss of Power
« Reply #1 on: July 25, 2018, 11:21:56 am »
Have you tried getting the DSG serviced. Think it’s around £170 to do at VW. Any history of it being done ?
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #2 on: July 25, 2018, 11:30:11 am »
Have you had it scanned for fault codes?
w4qas321
« Reply #3 on: July 25, 2018, 03:00:05 pm »
DSG service was done at 120k and the car is sitting currently at 128k, only fault code which comes up is P2293 which isnt a stored code but just a Pending code. Thanks
Offline minty7815
« Reply #4 on: July 30, 2018, 04:44:48 pm »
I'd start by replacing the fuel filter.
Offline Carpy25
« Reply #5 on: July 30, 2018, 08:36:03 pm »
Tank strainer on the pick up
Maybe it’s one thing making other things happen
Tank fuel Pick up blocks , Fuel pressure drops ,revs drop,  dsg drops down a gear as revs drop demand on fuel drops strainer clears a bit and things pick up or sometimes a turn of clears the debris back in to the tank
Just a thought maybe worth cleaning out the tank
Rob
