Author Topic: What to replace when subframe is off etc...  (Read 1589 times)
Offline oak_grun
« on: July 31, 2018, 08:50:05 pm »
Hi, I will be doing a overhaul of components on my Edition 30 shortly and would like some advice from people who have done something similar recently in terms of what I should replace whilst doing other bits and pieces etc...
So I will be replacing the following bits;
Engine mounts for Vibratechnics - full set including subframe mount
H&R Arbs
Anti Lift kit
H&R springs on standard shocks for now...unless I can get my hands on a set of Bilstein shocks in time...
Whilst the above is being fitted, is there anything else I should consider replacing at the same time?
Thanks in advance. :happy2:
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: What to replace when subframe is off etc...
« Reply #1 on: July 31, 2018, 10:49:28 pm »
check there is no play in the rack. Could take off the downpipe and not knock out the pre cat whilst the subframe if off.
could fit a deadset kit or fit the ecs shims with Passat bolts.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #2 on: August 01, 2018, 12:30:22 am »
Probably goes without saying, replace all bolts with new
Offline oak_grun
« Reply #3 on: August 01, 2018, 11:37:43 am »
New stretch bolts will be used on engine mounts  :happy2:
Anything else?
I think I've read some where that when fitting anti lift kit, it's worth changing bottom arm bushes too?
« Reply #4 on: August 17, 2018, 08:42:36 am »
You'll be needing a full set of subframe bolts as well as the engine mount bolts.  Everything that supports the drivetrain and chassis components uses stretch bolts.
I wouldn't bother with the front wishbone bushes personally, but the rear ones (ALK) is well worth doing.
Tyrolsport deadset is well worth doing.
Also a good time to check for split CV boots and other maintenance items.
