Author Topic: How do I know for sure that my Diverter Valve needs replacing?  (Read 2683 times)
Offline dadjokes
I've had my Mk5 GTI for about 3 weeks, and I absolutely love it. But like any new car I'm just getting used to it, and coming from a Mk7 Fiesta ST it's a different car altogether.
I've got no proof that the DV has ever been changed, and as I don't know how the car should respond with a healthy one, I'm not sure if it needs replacing or not.
Car pulls hard after about 2500rpm, only noise I can hear is a high-pitched 'siren' like noise from driver's side footwell which I assume is the turbo spooling?
If the DV was leaking, would the car be totally flat?
Offline Octoparrot
  • -Receive: 102
Re: How do I know for sure that my Diverter Valve needs replacing?
« Reply #1 on: August 01, 2018, 09:52:07 pm »
If it pulls like you say it sounds like it's fine.  :happy2:
« Reply #2 on: August 17, 2018, 05:32:42 pm »
You normally get under boost fault codes if the tear in the DV is severe.
For the sake of 50 quid and an hour fiddling around on the turbo, I would replace it anyway for peace of mind.
Offline dadjokes
« Reply #3 on: September 04, 2018, 12:59:33 pm »
Thanks all - got it replaced when the car was in for some other bits. Can't say it feels massively different, but just knowing it's sorted is good enough for me!
