Author Topic: Modified Evoms intake enclosure(pic heavy)  (Read 5123 times)
Offline Janner_Sy
  • -Receive: 113
« on: February 12, 2010, 11:41:24 am »
found this on SCN. quite impressive. seems like a good viable option for guys with evoms.
Quote
Quote from: hubbly_bubbly;2805591
I wanted to quieten down the overbaring sound of the intake for daily use. During highway driving it is particularly loud at cruising speeds. The noise, which seems to come through the glovebox and passenger footwell, all comes from the cone (well at least with an EVOMS it does), so that needed to be caged. Some research revealed a useful tutorial from the net on fibreglassing an air filter enclosure. Bought a couple of fibreglass repair kits from the local hardware store for R95 each, paint brushes and masking tape and I was good to go.
Before
The EVOMS partition and pipe (cone removed)
Making a mould of the cavity with masking tape, cardboard and newspaper to protect the car and engine bay from stray resin drops. I decided to make the enclosure two parts to add to the EVOMS partion. A bottom and sides was made first and the lid thereafter.
Moulding the ram air pipe to feed into the enclosure
The fibreglass sheets impregnated with resin (mixed with the provided catalyst). Its really great material to work with, once wet with resin it melts to the curves of the mould. Latex gloves come in handy (excuse the pun) when working with fibreglass sheeting and resin
The bottom and sides part of the enclosure dry and stripped from the cardboard mould
The bottom and sides of the enclosure installed back into the engine bay
A hole was cut for the ram air pipe to feed into the enclosure
The lid was made but profiling some cardboard, sticking it to the sides of the enclosure and then using masking tape to contour the CAI pipe. The resin impregnated fibreglass of the lid
« Last Edit: February 12, 2010, 12:04:55 pm by vRSy »
Offline Janner_Sy
  • -Receive: 113
Re: Modified EVoms intake enclosure
« Reply #1 on: February 12, 2010, 11:41:52 am »
Quote
Quote from: hubbly_bubbly;2805593
The dried and stripped lid
Using a dremel (pencil grinder type circular cutting tool) I cut off the excess fibreglass similarly to the bottom and sides half.
Using some more fibreglass (courtesy of my work :D) and resin i made a lip around the edge of the lid
The first lid was not smooth at all on the top surface and hence I had to take a mould of it and then use that negative to make another lid. The mould for the second lid. Using masking tape on the inside surface to give the smooth finish on the top surface of the lid.
The lid mk2 resined up in the mould
The lid came out the mould looking 100 times better than the first. It still wasn't as smooth as I wanted it to be so i proceeded to coat it with lots of thick coats of paint. This is one of the colours that I used, for all the chrono lovers ;)
Offline Janner_Sy
  • -Receive: 113
« Reply #2 on: February 12, 2010, 11:43:12 am »
Quote
Quote from: hubbly_bubbly;2805594
The finished bottom and sides
The finished lid, matt black which I thought would match the other black plastics of the engine bay
The bottom and sides of the enclosure installed on the car
The lid installed, completion of the enclosure
The enclosure works beautifully to keep the cone alot quieter. The consistant drone at 3000rpm during highway driving is gone. It hasnt completely silenced it only made it alot easier to live with everyday. When it comes time for dyno days, breakfast runs and drag races ill open up the enclosure to make some EVOMS noise and then close it up again for my week day commutes :) I am planning to do comparitive logs of air flow with the enclosure versus without. Ill post the results as soon as they are complete. It might be the case that the performance is better with the enclosure. In that case ill keep it on for performance events. Mass of air taken in and intake air temperatures should show that up pretty easily.
Re: Modified Evoms intake enclosure(pic heavy)
« Reply #3 on: February 12, 2010, 11:46:40 am »
Very impressive  :congrats:
« Reply #4 on: February 12, 2010, 11:58:28 am »
been thinking of doing the same to mine but might get something made up in the future
Offline jonnyc
  • Herrooooo!
« Reply #5 on: February 12, 2010, 12:03:08 pm »
Great idea for sure but you have to admit it looks a bit  :sick: With a little more time I think it would look great, especially if it were plasti dipped to match the engine cover..
Sure it does the job though  :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: February 12, 2010, 12:05:04 pm »
Should keep out all that hot engine air, and create a massive high pressure area around the filter from below the fog light and the front slam panel
  • -Given: 380
  • -Receive: 442
« Reply #7 on: February 12, 2010, 12:29:36 pm »
^^^^ My thoughts exactly.
Great concept but very amateur execution.. Fine test prototype.. Now go and make one or get one made that looks professional. Not that my efforts would be any better!
« Reply #8 on: February 12, 2010, 12:36:04 pm »
I love that mod :happy2:
Now you have had a practice you can make me one too :laugh:
Offline tony_danza
  • -Receive: 112
« Reply #9 on: February 12, 2010, 12:37:50 pm »
Great idea.
I suppose there's not much point in making a lot of effort to test a theory, but it doesn't look that bad. I'll be interested to hear how it performs  :happy2:
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #10 on: February 12, 2010, 01:37:14 pm »
not mine john. found it on SCn.
« Reply #11 on: February 12, 2010, 04:42:03 pm »
 :ashamed: My bad!
Get him to make me one then instead :laugh:
Offline tony_danza
  • -Receive: 112
« Reply #12 on: February 12, 2010, 04:45:49 pm »
Him?
Surely you don't mean him??
Sideways yo!
« Reply #13 on: February 12, 2010, 04:47:21 pm »
Him?
 :signLOL:
Ahh, yes I remember those films :laugh:
Offline Janner_Sy
  • -Receive: 113
« Reply #14 on: February 12, 2010, 05:36:38 pm »
^^^^^is it me or does that bloke look very similar to Ron jeremy
