Author Topic: Fitted SuperPRO Ball joints, hubs and brakes today - wheel alignment  (Read 1540 times)
Offline Christiank
  • -Receive: 39
Hi guys,
So want to know what you guys are running the alignment for front wheels?
I installed superPRO ball joints that can be adjusted like the Audi TT ones..
Not sure if this has some to say, but running 225/40/18 wheels and the car have Bilstein B12 sportline kit
Offline colesey
  • -Receive: 89
Re: Fitted SuperPRO Ball joints, hubs and brakes today - wheel alignment
« Reply #1 on: August 12, 2018, 06:36:45 am »
I run 1.5 deg of camber with my SP balljoints and would recommend similar on rear. Toe out is @5min on front and rear for quicker turn in.
« Last Edit: January 29, 2019, 12:32:41 pm by colesey »
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: August 14, 2018, 08:52:25 am »
sure Alex said -2.25 camber on the front
Offline colesey
  • -Receive: 89
« Reply #3 on: August 14, 2018, 10:56:19 am »
SP bjs won’t go out as far as 2.25, trust me I tried!
Offline Christiank
  • -Receive: 39
« Reply #4 on: August 20, 2018, 05:57:55 pm »
So guess.. Finally got the job done. Swapping from alloy hubs back to fresh refurbed steel ones.
As the topic tittle says the Superpro ball joints are also installed - However now I got a problem with the alignment of the front wheels.
The ball joints says "L" and R" so guessing not much can go wrong there. But I can't my passanger (right) side to be -1.5? In fact it doesn't go negative at all? Left side (drivers) is about the -1.50 … Think it's -1.47 or something right now since I need to figure out why I can't get right side negative..
Anyone got any ideas to what could be the issue?  :confused: :drinking:
