Author Topic: Will changing timing belt reset my remap  (Read 1626 times)
Offline Jgavin1
« on: August 16, 2018, 05:59:18 pm »
My edition 30 has a stage 1 remap on it and my timing belt/water pumps is due replacement soon. I’ve read that the battery needs disconnected to change the belt so could this reset the ecu?
Offline neilw
Re: Will changing timing belt reset my remap
« Reply #1 on: August 16, 2018, 06:02:44 pm »
No, should be fine.
You could do the belts without disconnecting the battery. Just be really careful not to accidentally try and start it! Its good practice to disconnect it.
Edition30 #0002 R-Tech Stage2
« Reply #2 on: August 17, 2018, 08:56:53 am »
It's only the Revo map that defaults to a reduced performance mode if the battery is pulled.  You need an SPS switch to re-enable the Stage 1 map, or a trip to a Revo dealer.
If you don't have a Revo map, pulling the battery won't affect anything.
As above, the battery doesn't need disconnecting to change the belt, but a lot of garages do it regardless as a precautionary measure.
