Author Topic: Smell of petrol in my oil :(  (Read 3432 times)
Offline Jgavin1
« on: August 16, 2018, 08:17:30 pm »
Hi. Just had my car remapped and thought best to do an oil change. I noticed there was a slight smell of fuel from the oil!
It’s indenting on changing the cam follower asap but could my fuel pump be knackered  ?
Cars an edition 30 with 88k. Going to rake through paperwork to see if the followers been done.
Offline gixerben
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92657.msg930393.html#msg930393
Re: Smell of petrol in my oil :(
« Reply #1 on: August 16, 2018, 09:01:33 pm »
mines only done 60k and it smells of fuel, cam follower changed and the car has been well maintained by myself and previous owners, I think it just the character of the engine..
Pirelli GTI
Offline colesey
  • -Receive: 89
« Reply #2 on: August 17, 2018, 06:38:47 am »
The seal in your HPFP could be on its way out.
Offline Jgavin1
« Reply #3 on: August 17, 2018, 07:36:01 am »
Do you know the part number for an oem replacement ?
« Reply #4 on: August 17, 2018, 08:48:57 am »
You need to establish if it just smells of over rich blow by, or neat fuel.    If you take the HPFP out and smell the oil around the seal and the recess it sits in on the chain cover, if it stinks of neat petrol, it's likely the pump, or a dribbling injector.  Any rough idling or cold starting issues?
Remapped engines do cause the oil to turn black and stink pretty quickly.  Tuners go way over the top with the fuel to cover their arses, and it means much more frequent oil changes as a result.
You can also rub a bit of the oil between your finger and thumb.  Diluted oil loses a lot of lubricity and won't feel as 'slippery' as it should.  That sounds weird I know, but it's an old school check I can't let go of  :grin:
If in doubt with the pump, just replace the whole thing.  It's about £180 from the dealer and you will get the latest revision.  It's been updated a few times over the years.
Offline Jgavin1
« Reply #5 on: August 17, 2018, 10:42:02 am »
Thanks for the info. I can’t find any history of the follower been changed so I’ve ordered a new one and a new fuel pump. Euro car parts doing a big sale so got a pump for £145 and a follower kit from awsome gti.
Idle seems ok but I’ve not taken much notice, I’ll check tonight
Cars only been remapped for a couple weeks and the oils been changed around the same time and it’s already smelling of fuel so I think it’s safest just to change the pump
« Reply #6 on: August 17, 2018, 04:06:38 pm »
Yeah it shouldn't be smelling strongly of petrol already, so probably best to change the pump and definitely the follower.
Didn't know ECP did the high pressure pumps.  So long as it's a proper Hitachi one, it should be fine.
Offline Jgavin1
« Reply #7 on: August 17, 2018, 06:40:48 pm »
It’s a pierberg pump. I just typed in my reg and it came up with that. Should it be ok?
Offline colesey
  • -Receive: 89
« Reply #9 on: August 17, 2018, 07:39:39 pm »
Best get that order cancelled as it is the wrong type pump! You need the HPFP which mounts in the cylinder head, made by Hitachi.
Offline Jgavin1
« Reply #10 on: August 17, 2018, 07:45:03 pm »
Thanks I’m meant to be collecting tomorrow but I’ll cancel it. Strange it says it’s meant for the BYD engine but isn’t the right one
Does anyone know the part number for the correct one ?
Offline colesey
  • -Receive: 89
« Reply #11 on: August 17, 2018, 08:50:26 pm »
There are two pumps in the system, the low pressure one which you ordered and the high pressure one (06F-127-025-M)
Offline Jgavin1
« Reply #12 on: August 17, 2018, 08:54:06 pm »
Yeh I just found that out! I’m such a novice at these things
