Author Topic: Mk5 to Mk7/Scirocco/Passat B8 climatronic retrofit  (Read 26030 times)
Offline Stupots
  • -Given: 18
Re: Mk5 to Mk7/Scirocco/Passat B8 climatronic retrofit
« Reply #15 on: April 18, 2021, 09:41:29 pm »
Hi @Sebas_theFish I certainly did. There’s a pic of it fitted here:
https://www.mk5golfgti.co.uk/forum/index.php/topic,30806.msg1140596.html#msg1140596
I’m really pleased with the mod
Offline Sebas_theFish
« Reply #16 on: April 17, 2022, 06:52:21 am »
I'm confused about what I do with Pin 1 from the AQS?
Offline Stupots
  • -Given: 18
« Reply #17 on: April 17, 2022, 07:53:05 am »
Yeah, so was I. :)
You take the wire from pin 20 and connect it to pin 1 of the AQS. So it's misleading when you read that it goes to pin 20. If that's confused you more read this threat and the reply from SI-R32: https://www.r32oc.com/threads/climatronic-upgrade-panel-air-quality-sensor-questions.99193/
« Reply #18 on: April 18, 2022, 09:29:02 am »
Well the initial retrofit seems to have gone quite well!
Might take another crack at making the trim piece as I didn't get it joining up quite right at the top and I know it's gonna bug me. Also happy with the paint match, I got it pretty much spot on first go. May go slightly darker if I decide to make another trim but it's a very close match.
Did you alter any of the coding options for the new climatronic unit and do you have any unclearable errors?
Thanks!
« Last Edit: April 18, 2022, 09:32:42 am by Sebas_theFish »
Offline Stupots
  • -Given: 18
« Reply #19 on: April 18, 2022, 06:01:50 pm »
You’ll get “ Function Restricted due to Missing Message(s)” but that is expected with these late panels in early cars and can be ignored.
For fit it’s hard to get the sharp line where it joins the other panel. To make a good job of this I wrapped some sandpaper around one end of a long/thin bit of wood, say 1cm x 60cm, and sand each one whilst the other end rest on the other bit if you see what I mean. This ensures they are straight and at the same angle to each other, if you’ve cut them to the correct length, it also avoids them going slightly rounded when sanding freehand. Colour match looks good 👍
« Last Edit: April 18, 2022, 06:04:23 pm by Stupots »
« Reply #20 on: April 19, 2022, 12:22:11 am »
Thanks for the tips.
Didn't you also do the single flap conversion?
How hard is that to do or is it even worth it because my new panel is working fine?
Sent from my Samsung Smart Fridge
Offline Stupots
  • -Given: 18
« Reply #21 on: April 19, 2022, 03:53:50 pm »
I wouldn't do it again in a hurry, it was a horrible job. It will probably easier if I'd just bitten the bullet and taken the dash out, trying to loosen things enough on passenger side to get things out and in was a pain.
Time has passed, but I remember thinking at the time, never again.
« Reply #22 on: April 20, 2022, 03:44:30 am »
Good excuse to do a Mk6 dash swap then
One day...
Offline Islam Zaki
  • Newbie
« Reply #23 on: February 22, 2025, 10:39:49 am »
I also wish you could buy these trim surrounds off the shelf like you can for the Mk6 controls.
I am working towards getting my controls, Air quality sensor and single motor flaps fitted, but need to get the trim right first... My first attempt is coming along better than I thought it would.
Paint match on lower trim matches nicely I think.
Even got all the right fixings at the top.
I'm doing this as I think it looks the nicest out of all 3 Climatronic controls (mk5/mk6/mk7 style). I really dislike the heated seat controls on the mk5... a volume control with a number on it. I also wanted the controls to show on my RNS510, which the mk5 controls don't do.
Hopefully I won't mess it up.  :laugh:
I need one ac sround trim if you can make one for my and i will pay to you all the cost requsted.
Thanks in advance
