Author Topic: Gearbox oil recommened  (Read 1581 times)
Offline Trav Turbo
  • -Given: 18
« on: August 24, 2018, 09:12:33 am »
Hello all! Going to be doing and oil change on my Manuel gearbox with a service soon. What's the best oil to use on a mk5 Golf Gti and experiences?
Sent from my SM-N910F using Tapatalk
Offline Molesy
Re: Gearbox oil recommened
« Reply #1 on: August 24, 2018, 10:00:08 am »
best oil is the stuff you get from VW, stick with OEM for this one. Available from TPS/VW etc
Molesy  :happy2:
Offline colesey
  • -Receive: 89
« Reply #2 on: August 24, 2018, 02:46:33 pm »
Definitely OEM. Shifts better than the Millers NT gearoil I had before.
Offline The Red Warrior
« Reply #3 on: August 25, 2018, 11:23:12 am »
I’ve been using Motul. Put some in when I got the car at 107,000. When I changed it when installing my LSD at 165,000 it was still in good condition.
Offline MK1Campaign
« Reply #4 on: August 25, 2018, 12:03:28 pm »
Stick with Oem. I changed to Fuchs which was OE spec but it made 2nd gear notchy.
« Reply #5 on: August 30, 2018, 04:35:51 pm »
The dealer oil is the best there is, period  :happy2:
Offline colesey
  • -Receive: 89
« Reply #6 on: August 30, 2018, 05:34:43 pm »
Out of interest, how do you find the cold weather change into 2nd gear with the Motul? This seems to be the acid test for gear oils on our cars.
« Reply #7 on: August 30, 2018, 06:00:42 pm »
The OEM oil is like water compared to the aftermarket options.  Super thin.
RoyalPurple Synchromax might be worth a look.  Honda gearboxes are equally as fussy as VW boxes with oil, and Honda boys have had good luck with the RP.
