Author Topic: Gti clutch on an edition 30  (Read 2355 times)
Offline muff1991
  • -Receive: 69
« on: September 09, 2018, 12:49:18 pm »
Quick question... will a Mk5 gti clutch and flywheel fit onto an edition 30 perfectly?
I would have thought so, but my cousin wanted some reassurance 😂 Thanks
Re: Gti clutch on an edition 30
« Reply #1 on: September 09, 2018, 04:32:44 pm »
They are the same parts  :happy2:
Offline muff1991
  • -Receive: 69
« Reply #2 on: September 09, 2018, 06:16:57 pm »
Thanks pudding, thought so just wanted to double check! Much appreciated 👌🏻👍🏻
Offline gtipirelli
  • Golf GTi Pirelli
« Reply #3 on: September 12, 2018, 11:53:01 am »
Am I right in thinking that a TDi clutch from a similar age golf also bolts in to an ED30 or Pirelli Edition for those getting a little clutch slip on a remap
Would that work out better value than going for a Sachs or something ?
Golf GTi Pirelli - Diamond Black, 5 Door - SOLD
now 718 Cayman S PDK
« Reply #4 on: September 13, 2018, 09:51:14 am »
TDI & GTI/ED30/Pirelli = same clutch  :smiley:
A popular oem upgrade in the states is TTRS cover with stock GTI friction plate and dmf. Good for 450lbft but still a light pedal.  You can’t use the TTRS friction plate because the TT’s input shaft is much bigger.
Offline colesey
  • -Receive: 89
« Reply #5 on: September 13, 2018, 10:03:27 am »
And this is indeed the basis of the HS Tuning RSR kit. Plenty of stuff online about diy versions but good to use OEM parts where possible.
Offline gtipirelli
  • Golf GTi Pirelli
« Reply #6 on: September 13, 2018, 11:53:35 am »
Any idea how much a TDi clutch is to purchase and fit
Offline muff1991
  • -Receive: 69
« Reply #7 on: September 15, 2018, 07:19:37 pm »
it will be much cheaper to  do the job yourself if you can, and just have a look around for the clutch for your car, it will give you a rough idea. if you cant do it yourself... then best off phoning an indy for a quote.
« Reply #8 on: September 21, 2018, 03:47:09 pm »
No point going for TDI specifically as it's the same clutch as the GTI as I already stated.
Good shout on doing it yourself if you have the tools and an engine support cradle (sits across the inner wings).
I managed to hammer my local dealer down to Eurocarparts level prices for a genuine DMF and clutch, which is always the recommend choice.  Without discount, they are horrendous money.
