Author Topic: Car shaking 80-100  (Read 4598 times)
Offline Rigsby
  • -Given: 22
Car shaking 80-100
« on: October 01, 2018, 11:51:50 am »
Any ideas folks?
Having a nightmare, all started when I had x2 Michelin tyres put on the front.
Took back for rebalance, still there took somewhere else and said I had slight buckle on drivers front wheel. So bought some more wheels and had tyres put on, vibration still there, rebalance again and still there.
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Car shaking 80-100
« Reply #1 on: October 01, 2018, 01:23:36 pm »
Obviously...you're only doing 70mph  :driver: :P :signLOL:
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline Dogma
Car shaking 80-100
« Reply #2 on: October 01, 2018, 01:25:07 pm »
Im sure he means kph
Could be a wheel bearing
MK5 ED30
Offline Rigsby
  • -Given: 22
« Reply #3 on: October 01, 2018, 02:15:50 pm »
On track obviously.
Wheel bearing?? I’m not getting any humming noises
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #4 on: October 01, 2018, 02:47:53 pm »
are you missing a spigot ring?
Offline Rigsby
  • -Given: 22
« Reply #5 on: October 01, 2018, 03:42:49 pm »
I’ve checked that and the original wheels didn’t have them
Offline andyR43
« Reply #6 on: October 01, 2018, 06:56:56 pm »
Swap your front wheels with those on the back, go back out on the track and if the problem is still there then it is not your wheels or tyres.  :happy2:
Keeping it original..............or not!!
Offline Rigsby
  • -Given: 22
« Reply #7 on: October 02, 2018, 02:52:27 pm »
Swapped wheels front to back and still doing it.
The more I plant my right foot the worse the shaking is??
Offline andyR43
« Reply #8 on: October 02, 2018, 09:23:09 pm »
As mentioned before check your wheel bearings for play. Mine didn't make a noise initially, started to vibrate then before I knew it the one side overheated and seized solid!! :surprised:
Offline Rigsby
  • -Given: 22
« Reply #9 on: October 04, 2018, 11:05:46 am »
I’ve found a little play in drivers cv joint, think the inner.
Passenger side  is solid.
You think this would cause high speed wobble?
Also what’s with the different codes on the driveshafts? Can’t find any that match my code of 2k jj
« Last Edit: October 04, 2018, 11:09:18 am by Rigsby »
Offline muff1991
  • -Receive: 69
« Reply #10 on: October 04, 2018, 02:23:06 pm »
does it do it only when accelerating or just generally? can you feel it through steering wheel?
had this on my touran only when accelerating, after a tire change and replacing wishbone bushes, passenger front spring, and a 4 wheel alignment it went away.
Offline Rigsby
  • -Given: 22
« Reply #11 on: October 04, 2018, 06:41:51 pm »
Does it at varying speeds from 70 onwards , it’s slight but uncomfortable when cruising but if I plant my right foot the shakes will get worse
Deep down I still think it’s balncing but it’s been done like 5 times........may try a road force balance?? Anyone had that done?
« Last Edit: October 04, 2018, 06:43:45 pm by Rigsby »
Offline muff1991
  • -Receive: 69
« Reply #12 on: October 05, 2018, 04:29:51 pm »
on my touran I have lacquer peel on the inside and found weights was coming off, so I told the guy to scrape it off when installing weights. whether it was the actual tyres or the balancing I'm note sure, you have had new tires though, so I'm guessing balancing too. take it somewhere else and ask for balancing. mine used to shake when accelerating. quite bad too! (and at higher speeds)
Offline andyR43
« Reply #13 on: October 05, 2018, 07:37:04 pm »
Sort out your cv joint as this is most likely your problem. Not much life left in it if you can feel play in it and most probably where your vibration is coming from.  :happy2:
« Reply #14 on: October 06, 2018, 10:07:45 am »
Had this on mine and it was balancing. In the end I got the dealer to do it and the problem went away.  Pretty much every time I use a big name tyre place, I get steering shake past 80 leptons. I will just use the dealer going forward.
Check your brakes aren’t warped. Another common cause.
« Last Edit: October 06, 2018, 10:09:58 am by Pudding »
