Author Topic: Mark 5 GTI battery drain issue, not the stereo.  (Read 3288 times)
Offline Paulo P
« on: October 02, 2018, 12:49:38 pm »
Hi,
I have a bad battery drain on my Mark 5 GTI which is killing the battery in less than 2 weeks. At first I suspected it was the stereo and maybe someone had changed my head unit but found that it wasn't that.
With the car locked I can see this drain.
Remove fuse F3 from the engine bay
and the drain instantly drops to this
A google search suggests that fuse F3 is for the multi function on the clocks, has anyone experienced this drain before and cured it?
Thanks  :happy2:
Offline Paulo P
Re: Mark 5 GTI battery drain issue, not the stereo.
« Reply #1 on: November 01, 2018, 01:26:40 pm »
Anyone come across this?
« Reply #2 on: November 02, 2018, 08:35:24 am »
It won’t be for the clocks at 20 amps!  I’ve seen another reference saying it’s for the ‘onboard power supply module’ whatever that is!
I guess with that fuse pulled, figure out what no longer works on the car, or plug in a scanner and see there’s any power supply type fault codes.
Unfortunately F3 is not mentioned at all in the handbook.
Offline Dogma
« Reply #3 on: November 02, 2018, 09:06:10 am »
How old is this battery?
MK5 ED30
Offline Paulo P
« Reply #4 on: November 02, 2018, 11:14:05 am »
I'll have to try that then, I was hoping that it was something that somebody had already come across. Thanks.
Offline Paulo P
« Reply #5 on: November 02, 2018, 11:15:36 am »
The battery is about 8 months old, it previously killed a Bosch S5 in 10 months from new when it went flat unnoticed.
Offline Paulo P
« Reply #6 on: November 13, 2018, 04:49:04 pm »
I've just got around to removing that fuse to see what stops working and it's the remote locking. With fuse F3 removed, the remote locking doesn't work and neither does the central locking via the drivers door lock. The central locking still works via the button inside the car though.
Has anyone got any ideas what part that could point at?
Offline Paulo P
« Reply #7 on: November 21, 2018, 11:26:52 pm »
Anyone? I notice that the alarm LED is still flashing on the drivers door when I lock it manually which says to me that it's not the alarm that's causing this drain. A few years ago the alarm siren used to go off on it's own but it's not happened for years, even when the battery drains. I still wonder whether it could be linked to that?
Offline muff1991
  • -Receive: 69
« Reply #8 on: November 22, 2018, 03:27:21 pm »
could be linked... but not certain.
I knew someone whos battery would drain and it turned out to be the boot lid wasn't shutting off the boot light when closed. wasn't a VW but anything's work a check.
Offline mo
« Reply #9 on: November 22, 2018, 09:02:38 pm »
Apparently there are 2 identical relays in the engine bay fuse box that can cause battery drain if faulty.
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
