Author Topic: Rear right wheel speed sensor  (Read 730 times)
Magners22
« on: October 06, 2018, 06:10:05 pm »
Hi all I am new to this forum so not sure if this in in the right place. I have bought a mk5 gti a few months ago with the cam chain rattle so got the car cheap and changed the chain and adjuster and tensioner! Engine now smooth as. The problem I now have is the rear speed sensor saying short circuit open to valve not sure what it means by valve. I have changed the sensor and wheel bearing as the magnetic ring was not the best and still get this code. I have also bought a new wire and plug and cut the old loom to the fixing point by the caliper and joined a new one as thought that in May have a break in that part as it will always have movement from the suspension. Has anyone else been in this situation before??? Cheers
