Author Topic: Any ideas how to remove my vinyl?  (Read 6662 times)
Offline WhiteGTI
  • F-A-S-T
« on: February 14, 2010, 09:14:52 am »
I'm guessing that it just requires a bit of heat and then it will progressively peel off. Then I'll just need a bit of polish to get rid of the residue.
Anything else I should know??
Cheers!  :happy2:
2006 E46 BMW M3 - 343hp
  • -Receive: 81
Re: Any ideas how to remove my vinyl?
« Reply #1 on: February 14, 2010, 09:25:54 am »
Bit of heat and do it slow
Offline QD MBE
  • -Receive: 102
« Reply #2 on: February 14, 2010, 09:26:53 am »
Not sure polish will shift the residue.  If it doesn't use some WD40 or similar and that will soften the residue.  Will have to degrease and polish after though.
Heat is your friend when removing vinyl.
Offline WhiteGTI
  • F-A-S-T
« Reply #3 on: February 14, 2010, 09:37:06 am »
^^^ Thanks both! Much appreciated  :happy2:
Offline QD MBE
  • -Receive: 102
« Reply #4 on: February 14, 2010, 09:40:03 am »
Pull gently at 180 degrees, ie pull it right back over itself, and slowly.
Fnarr fnarr! :signLOL:
Offline tony_danza
  • -Receive: 112
« Reply #5 on: February 14, 2010, 10:13:03 am »
AG tar remover gets shut of the residue.
Sideways yo!
Offline Poppa Dom
« Reply #6 on: February 14, 2010, 10:26:07 am »
Chris,
Boil the kettle and soak s sponge in the hot water, place the sponge over the vinyl for a few seconds and it will soften the adhesive. I used the edge of a credit card flush with the body work to lift a corner and then slowly peel.
Offline bacillus
  • -Receive: 451
« Reply #7 on: February 14, 2010, 10:28:21 am »
Chris,
Wouldn't heating using a hair drier be less messy?
Offline WhiteGTI
  • F-A-S-T
« Reply #8 on: February 14, 2010, 02:12:17 pm »
Chris,
Cheers Dom! I'll give that a try!  :smiley:
Offline big al
« Reply #9 on: February 14, 2010, 05:48:08 pm »
Stand at approximately 40 degrees to the car with a peacocks feather stuck to the back of your jeans, then shout taddaaaa 3 times, and it should come off with ease!   :wink: :happy2:
What vinyl you taking off btw?
Offline WhiteGTI
  • F-A-S-T
« Reply #10 on: February 14, 2010, 06:15:46 pm »
Bonnet and roof, in preparation to sell the car  :smiley:
« Reply #11 on: February 14, 2010, 06:44:33 pm »
as said, warm and slow dude  :laugh:
i have spray vinyl adhesive remover i can supply should you need it, breaks down the glues left behind on the paintwork :happy2:
Offline WhiteGTI
  • F-A-S-T
« Reply #12 on: February 14, 2010, 06:52:14 pm »
Thanks VC. I'll see what the paintwork looks like after the vinyl is off and decide if I need any, much appreciated  :happy2:
« Reply #13 on: February 14, 2010, 06:56:00 pm »
no worries mate, usually used for vinyls that have been on vehicles for quite a while, s'only a little pump spray - very handy stuff when youre tackling aged vinyl or on an area such as the bonnet which has heat transfer to the glue and can make it quite brittle when you peel
hopefully you'll just get away with a good wash  - run the engine to warm the bonnet... and avoid petrol/wd40 over such a large area  if you plan to use it :happy2:
Offline Strat
« Reply #14 on: February 14, 2010, 07:40:54 pm »
Prepare the surface with something like a domestic iron, then rip it off as quickly as you can to avoid any damage to the bonnet!
Candy
