Author Topic: High line cluster: audio/navigation, revo sps pro  (Read 6021 times)
Offline phas3r
« on: October 27, 2018, 08:52:25 am »
Finally got my hi line fitted into my mk5, but cant access phone menu (it skipped) and audio and navigation are nowhere to be found. Should they be available by default? Im thinking of adding revo sps pro to the car, will that fix it?
08 MKV GTI DSG shadow blue
Engine: Revo Stage 2 7-3-9 | Forge Twintake | S3 Intercooler | R8 Coils | APR RSC MK6 Catback + 3" DeCat Downpipe
Brake/Susp : Golf R 345mm Front | Michelin PS4 225/40/18 | BBS CO VZ033 18" | H&R Rear ARB | S3 Lower Arm Bush
Interior: RNS 510 | 9WZ | Retrofitted CC | MK6R Rev Cam | Midline cluster :(
Offline Pashka
Re: High line cluster: audio/navigation, revo sps pro
« Reply #1 on: October 27, 2018, 01:34:05 pm »
You wont see phone menu on red dash unless you fit polar fis bluetooth or polar fis advance adapter. New bluetooth modules don't support red dash. For audio and navi you need to code the unit.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline phas3r
« Reply #2 on: October 27, 2018, 03:06:16 pm »
How can i code the unit?
Should have gone for mk6 mfd. red are rather limited it seems.
Offline Pashka
« Reply #3 on: October 28, 2018, 11:46:30 am »
Just change a coding of unit with any  vw tool.
Offline phas3r
« Reply #4 on: October 29, 2018, 02:32:40 pm »
May i know how can i do it?
Offline Pashka
« Reply #5 on: October 29, 2018, 05:29:35 pm »
Have you got VCDS?
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #6 on: October 30, 2018, 08:01:49 am »
Can code it to display audio and nav, BAP coding on or off.
...but then you'll lose the convenience menu, and live it
(annoying but once you've setup convenience, never really change them).
I have a polarfis advance plus somewhere, pf03 kessy, which I'd part with.
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline phas3r
« Reply #7 on: November 05, 2018, 03:43:08 pm »
No VCDS but can get to the nearby place for it.
I am alright with losing convenience menu i guess. Cant do much with it. Just comfort, units, winter tires, language i think. Not much to change.
Any steps with the BAP coding? Hopefully with audio i can switch tracks by steering wheel
Im not from the uk.
Offline phas3r
« Reply #8 on: November 20, 2018, 08:01:29 am »
Based on google searches, going to VCDS>navigation 37>coding 07>long coding helper>disable BAP should do the trick
tried it but no difference. did i miss anything ? is it possible to simply a copy a similar long coding from someone who are able to access the audio & navigation bits.
Offline Dannyboi#722
  • My Ride: GOLF GTI EDITION 30 TTE480 BHP 446 & 443FT*LB FORGED (Mapped by R-Tech)
« Reply #9 on: November 20, 2018, 10:06:47 am »
Navigation 37>Codling>07>Long coding Helper, Byte 7.> 4&5 00 Display variant high line tick box. Press do it
Sent from my EVA-L09 using Tapatalk
Offline phas3r
« Reply #10 on: November 20, 2018, 10:35:01 am »
Didnt that just change the color of the rns510?
« Reply #11 on: November 20, 2018, 10:36:55 am »
No it doesn't mate, should bring up radio stations, sat nav, in the high line custer.
Offline phas3r
« Reply #12 on: November 20, 2018, 01:33:03 pm »
Did it, it changes my rns to grey color, i get no more sound, cluster no change still.
Reverting back to my previous settings soon
https://www.my-gti.com/1214/changing-the-volkswagen-rns-510-colour-scheme
Offline Pashka
« Reply #13 on: November 20, 2018, 01:57:53 pm »
Theme changing has nothing to do with the sound, change the coding for the amp.
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #14 on: November 29, 2018, 01:16:36 pm »
You also need to co in can gateway
check the items fitted in car.
phone, gps, satnav....
there's a huge list to tick the boxes that apply and ok
