Author Topic: Heel and Toe  (Read 5934 times)
Offline jamesh72
Heel and Toe
« on: February 14, 2010, 02:25:30 pm »
Hi chaps,
not had my ED30 very long, so haven't really had time to drive it very much, but is anyone managing to heel and toe in the mkv gti?
I thought it was going to be quite easy with the floor hinged throttle pedal, but the brake pedal is very high, so I can't just roll my foot over and blip the throttle.
I know its not strictly necessary, but I find it makes braking and changing down nice and smooth.
Offline WhiteGTI
  • F-A-S-T
Re: Heel and Toe
« Reply #1 on: February 14, 2010, 02:47:47 pm »
I don't have an issue doing it, however I can only do it properly with one particular pair of Puma shoes....!
Not as easy as in a BMW...they have their pedal set up just about right IMO!
2006 E46 BMW M3 - 343hp
Offline jamesh72
Re: Heel and Toe
« Reply #2 on: February 14, 2010, 02:58:08 pm »
I probably need to practice a bit more.
I've had a couple of beemers in the past, and found them to be spot on.
It required quite a bit of practice in my mk2 elise (no brake servo), to ensure I had enough braking pressure, but once I'd got the technique it was fine, so I think just more practice.
Offline WhiteGTI
  • F-A-S-T
Re: Heel and Toe
« Reply #3 on: February 14, 2010, 03:05:54 pm »
^ Interesting! I'm a S1 Elise owner too, very easy in that as the pedals are so close, but you're right it does take a while to get used to the lack of brake servo!
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: Heel and Toe
« Reply #4 on: February 14, 2010, 03:27:49 pm »
as far as im aware you cant heel and toe these cars. Press your foot on the accelerator and brake both at the same time and see what happens :happy2:
Offline chungster
Re: Heel and Toe
« Reply #5 on: February 14, 2010, 03:36:49 pm »
i do it all the time now.....especially out on track and with the Sachs clutch being alot grabbier than OEM i find it's much happier changing into the lower gear if i raise the revs with heel/toe technique.
Nasir
Re: Heel and Toe
« Reply #6 on: February 14, 2010, 04:54:09 pm »
The car disables the throttle if the brake is pressed with it for safety reasons. Not sure how that affects heel and toeing.
Offline jonnyc
  • Herrooooo!
Re: Heel and Toe
« Reply #7 on: February 14, 2010, 05:58:16 pm »
Thats only the case if the brake is depressed after the throttle.. Just to avoid someone dragging the brakes without noticing..
Offline jaydubveedub
Re: Heel and Toe
« Reply #8 on: February 15, 2010, 08:00:18 am »
I find the MK5 a very easy car to heel and toe in, thanks for the throttle pedal design.
It's very shoe dependent though..... :happy2:
Offline scotta
  • Edition 30
Re: Heel and Toe
« Reply #9 on: February 15, 2010, 10:20:49 am »
x2
Offline bennylenny88
  • needs moar lowwww
Re: Heel and Toe
« Reply #10 on: February 15, 2010, 12:13:10 pm »
i got a guide here lads  :happy2:
Re: Heel and Toe
« Reply #11 on: February 15, 2010, 01:57:58 pm »
That looks good Benny!  :happy2:
Shame I can't read it though!  :laugh: What is that from?
Offline QD MBE
  • -Receive: 102
Re: Heel and Toe
« Reply #12 on: February 15, 2010, 02:00:16 pm »
specsavers brochure................
 :rolleye:
Re: Heel and Toe
« Reply #13 on: February 15, 2010, 02:04:58 pm »
 :rolleye:
 :booty:
Re: Heel and Toe
« Reply #14 on: February 15, 2010, 02:19:42 pm »
Isn't this heel and toe thing what Robin always does, or am i getting confused with him putting his foot in it all the time.  :laugh:
