Author Topic: Caddy 2.0tfsi engine swap clutch issue,  (Read 638 times)
Calumcaddy
« on: November 11, 2018, 02:35:23 pm »
Hi guys, just wondering if you guys have come across this problem in your
Golfs, I have a 2010 caddy I have engine swapped 2.0 tfsi running stage 2, it’s a beast!! Clutch was slipping so I upgraded to helix organic with luk dmf! And changed release bearing too, now the clutch pedal is drifting away, mostly when in 6th gear, if I let off the accelerator the pedal drops to half way down but springs back up when I accelerate again... tried bleeding again and again any help would be awesome, also fitted an aks braided clutch line
