January 09, 2025, 09:33:29 am
All Things Mk5
Technical Workshop
MK5 GTI potential purchase - some issues
Topic: MK5 GTI potential purchase - some issues (Read 1726 times)
H4MXU
Always Involved
-Given: 34
-Receive: 1
November 21, 2018, 11:14:02 am »
Hi guys, new here and first post. Hopefully this is the right place.
I’m maybe going to view a manual GTI soon. It has about 140k on the clock with full service history (mainly VW).
Last MOT shows that the “supplementary restraint system warning lamp indicated a fault” (which failed MOT), owner says issue has been resolved and said I can call garage and confirm, doesn’t have receipts. Owner said light could appear because of some glitch in system or when something gets disconnected. Is this anything to worry about? Said light isn't showing on dash anymore.
Also last 2 years MOT shows the following as an advisory: “Nearside front outer drive shaft joint constant velocity boot severely Deteriorated”. Is this a major issue? How much am I looking at for repairs?
Any help would be appreciated and if you could tell me other things to look out for. Thank you.
Last Edit: November 21, 2018, 11:15:42 am by H4MXU
Dogma
Always Involved
-Given: 5
-Receive: 15
Reply #1 on:
November 21, 2018, 11:16:22 pm »
Sounds a little fishy to me, but I’m not an expert. It’s also sounds like his a little lazy getting things sorted. Best get the car checked out before buying, as you never know what’s hiding.
MK5 ED30
colesey
Just look at my post count
-Given: 6
-Receive: 89
Re: MK5 GTI potential purchase - some issues
Reply #2 on:
November 22, 2018, 06:59:55 am »
The CV boot issue is common and quite easy, albeit messy. to replace. @£20 parts and maybe £100 labour.
pudding
Global Moderator
-Given: 2
-Receive: 690
Reply #3 on:
November 23, 2018, 11:09:27 am »
He was probably messing about with the radio and removed the upper vent panel, which has an colostomy bag warning light in it. If there was a persistent bag issue, the light would keep coming back, so if it's not on, don't worry about it.
All Things Mk5
Technical Workshop
