Author Topic: 05 axx golf gti starts then cuts out instantly  (Read 2148 times)
golfv502@gmail.com
« on: December 02, 2018, 04:29:47 pm »
hi all new here with a strange problem on my 05 gti it starts then dies instantly then the exclamation light flashes an the dash beeps three times a friend used a small handheld scanner an came up with three codes p0230 p0686 p0688
Offline muff1991
  • -Receive: 69
Re: 05 axx golf gti starts then cuts out instantly
« Reply #1 on: December 02, 2018, 05:56:50 pm »
Have you googled these codes?
Offline Dave aka
« Reply #2 on: December 03, 2018, 11:27:04 am »
It’s the fuel pump control module at a guess with them codes, cheap enough to do and if you ask on here nice enough someone may now what to do and how to test the continuity going to/from the sensor............or possibly crank sensor?!?!? Get a proper diagnostic report off someone with Vag com or equivalent as that will help pin point it loads easier
