Thanks. Its not putting an engine light on, just literally a limp mode when using high rpm/power up a gradient. I changed the inline fuel filter and its massively helped with cold starts. The n276 valve makes a ticking noise, and if you unplug it the epc dash light comes on, and it reads the correct ohms, which suggests the solenoid works Im thinking the #p2293 for me could be the low pressure fuel pump? Is this possible?
Sent from my E5823 using Tapatalk
