Author Topic: 2.0 TFSI BWA - Oil pressure  (Read 1540 times)
Offline cosminstanciuro
« on: December 24, 2018, 05:02:01 pm »
Hello
I am trying to find out if somebody encountered this situation before.
Engine in cause - 2.0 TFSI BWA EA113
In VCDS - Instruments - Adv.Meas. - Oil Pressure (Here we have 2 possible values shown - 1. OK ; 2. <min)
After the engine is completely warm, rather I would say hot (coolant temp. 91-93) - is there anybody who have the value shown "<min") only at idle (750 rpm) ?
As soon as the idle is raised just a little bit (800 rpm) - OK is shown.
Oil pressure sensor good. Tested with mechanical gauge - pressure good.
Thanks.
Offline ady-gti
Re: 2.0 TFSI BWA - Oil pressure
« Reply #1 on: December 25, 2018, 07:30:17 pm »
Could be the oil pickup pipe blocked, it's very common with long life servicing that these become blocked over time.
Drop the sump and take a look at it.
« Reply #2 on: December 26, 2018, 08:01:26 am »
@ady-gti
Thanks for your reply.
I thought about this also but I am not sure considering the following :
- At cold start the value it shows OK until the oil is completely warm
- Oil was changed 7-9K
If anybody would be curios to let me know what value they have (Instruments - Adv.Meas. - Oil Pressure)  when the car is completely warmed, I would appreciate that.
Thank you very much.
