Author Topic: ** Jetta (MK5) Heater Blower Issues + Fault Code - NEED HELP PLEASE **  (Read 1651 times)
Offline XxMK5xX
First Of All - Hiya (New To This)  :happy2:
Wondering If Someone May Be Able To Help Me!
Have A Issue With The 'Heater / Dual Zone Climate' On My VW Jetta 2006 2.0 TDi Sport.
I Seem To Have Cold Air Blowing Down From The Passenger Footwell - Doesn't Seem To Be Blowing From The 'Vents' Though & The Controls Don't Seem To Want To Blow Air Out Of What Is Selected (Feet/Face/Windscreen Etc - Although Sometimes It Does - The Cold Air Is Always Blowing Though When The Blowers Are On!).
I Have Scanned The Car With An Aftermarket 'Scan Tool' & This Is The Following Fault Code:
01274 - 096 Canbus 01/01
Air Flow Flap
Position Motor (V71)
Static - No Define
Are The Two Above Problems Due To This? - Any Help Would Be Brilliant
Thanks In Advance
Offline muff1991
  • -Receive: 69
Re: ** Jetta (MK5) Heater Blower Issues + Fault Code - NEED HELP PLEASE **
« Reply #1 on: January 08, 2019, 09:22:51 am »
hi, if you google that code, theres quite a few bits on it.. should defo help you out and point you in the right direction :)
Offline XxMK5xX
« Reply #2 on: January 09, 2019, 04:20:16 pm »
Thank You For Your Reply  :happy2:
I've Had A Look On The Internet, But I'm Still Having Trouble Finding Out Exactly Where This Motor Is Located On The Jetta & If That Would Cause The Cold Air Problem Too.
Has Anyone Got Any Diagrams Of The Exact Location Of The Motor / Repair Guide & Maybe A Part Number (I Expect Its Going To Cost ££££!!!!)
Thanks In Advance
Offline andyR43
Keeping it original..............or not!!
Offline XxMK5xX
« Reply #4 on: January 10, 2019, 09:48:02 am »
That Looks Brilliant - Thank You
Just Need To Find Out The Part Number For That V71 & Hopefully That Will Also Cure The 'Cold Air' Issue Too
Any Ideas What The 'Static' Part Of The Fault Code Means - Do It Mean It Is Not Working At All?
Thanks Again
