Author Topic: ** Alarm Siren Fault & Code - Replacement Advice **  (Read 3803 times)
Offline XxMK5xX
« on: January 10, 2019, 04:32:05 pm »
Hi
Looking For Some Information On Replacing My Alarm Siren.
I Am Assuming That This Fault Means 'Replace' The Unit!
00134 - 100
Alarm Horn (H12)
Sporadic 004 - No Signal / Communication
I Have Been Told That I Have This Part Number Fitted Is: IK0 951 605 A or C
But The New Part I Have Been Informed Is: IK0 951 605 F
Looking On The Internet The 'F' Part Number Seems A Different Shape (Compared To The A Or C).
Question Is Will The 'F' Fit?, Where Is It Located (Easy Job)? & Is My Fault The 'Siren'?
Offline Christiank
  • -Receive: 39
Re: ** Alarm Siren Fault & Code - Replacement Advice **
« Reply #1 on: January 13, 2019, 04:27:16 pm »
Located under right side front wing, so if you remove right front wheel and the inner arch you should see a metal box showing up under there..
You should replace it with a index C to be sure it will work with your mk5 Linbus speed
Offline XxMK5xX
« Reply #2 on: January 13, 2019, 06:04:56 pm »
Thank You - I'll Have A Look For The 'C' - Is It A Question Of Just Swapping? (Not Coding Or Anything)
MPS
« Reply #3 on: January 13, 2019, 06:51:42 pm »
The siren unit is, as stated above, contained within a metal box which itself is riveted to the car with pop rivets. Drill the rivets out and just use self tapping screws or if you have a rivet gun use that. See if any anti-corrosion measures are needed after drilling as well just to be safe. It's a crap place to put it, they could have put it in the boot like in most Audis.
Offline Octoparrot
  • -Receive: 102
« Reply #4 on: January 13, 2019, 07:17:01 pm »
Just removed mine today, pretty straight forward as stated above.
Offline XxMK5xX
« Reply #5 on: January 13, 2019, 07:27:15 pm »
Plug & Play?  :thinking:
MPS
« Reply #6 on: January 13, 2019, 07:37:29 pm »
Apart from the metal box, yep.
« Last Edit: January 13, 2019, 07:40:08 pm by MPS »
MPS
« Reply #7 on: January 13, 2019, 08:31:10 pm »
Did you drill the pop rivets out?
Offline Octoparrot
  • -Receive: 102
« Reply #8 on: January 13, 2019, 09:07:13 pm »
Yes I used a punch to push the middle bit through and then just used an 8mm dill bit to dill the heads off.
