Author Topic: S3 Brakes - anti squeal shim?  (Read 1390 times)
Offline Mk5. EWC
« on: January 15, 2019, 05:52:47 pm »
Should they have the non squeal metal shims like my bigger rear calipers or do the pads just sit in the caliper as pictured.
Thanks.
Offline muff1991
  • -Receive: 69
« Reply #1 on: January 15, 2019, 07:01:11 pm »
Are they rear calipers yeah? If so then yeah they usually have the metal shim.
Offline 99hagued
Re: S3 Brakes - anti squeal shim?
« Reply #2 on: January 15, 2019, 08:09:35 pm »
The rear brakes have shims, the front ones don’t  :happy2:
Offline Mk5. EWC
« Reply #3 on: January 15, 2019, 09:23:05 pm »
They are the front. So no shim, the pad just slides in.
Offline chigmuss
« Reply #4 on: January 16, 2019, 06:47:33 pm »
Looks like a nice glossy refurb on those but the paint in the grooves might be giving you issues binding on the pad. The stepped parts of the casting where the pad 'ends' slide in and out along could maybe do with filing back to metal so that the pads slide freely. Too much paint will bind them up as they try to slide.
Sammitawn
S3 Brakes anti squeal shim
« Reply #5 on: January 16, 2019, 08:39:08 pm »
thanks mate   thats awesome..i thought of the idea to use the h&R wheel spacers but im not sure it will work..just to be sure you are talking about the 6 pistons brakes right?
