Author Topic: Removing pistons from calipers?  (Read 956 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« on: January 20, 2019, 04:02:04 pm »
Hi, I've bought some front calipers from a boxster to fit to my golf.
So far I've only been able to extract one of the four pistons.
I can't find a specific tool for it.
Any ideas?
Offline Carpy25
Re: Removing pistons from calipers?
« Reply #1 on: January 20, 2019, 08:23:43 pm »
Are they rears that screw in and out or fronts that just slide ?
The wind out one requires a tool
You can remove the sliding ones by using a brake hose clamp on the flexible hose opening the bleed nipple a little and connecting a foot pump the pressure of the foot pump will pop the cylinder out
Do it slowly and somewhere clean
You can use a air line but there’s more control with a foot pump
Rob
Offline v4rley
  • -Receive: 104
« Reply #2 on: January 20, 2019, 08:51:14 pm »
Think the issue is they are 4 pots? So assume once one remove there isn’t ability to use pressure to remove the other?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #3 on: January 20, 2019, 09:17:15 pm »
They didn't come with any brake hose on them so I don't know where I'd connect the footpump or airline.
Offline v4rley
  • -Receive: 104
« Reply #4 on: January 20, 2019, 10:28:56 pm »
Connect foot pump to the bleed nipple, but then you need to block the hose where the hose would be connected
