Author Topic: ** Best 'Top Mount' Advice Needed - Jetta / Mk5 **  (Read 8790 times)
Offline XxMK5xX
« on: January 29, 2019, 05:53:08 pm »
Hi
Looking for some advice / recommendations on 'Front Top Mounts' for my Jetta Sport 2.0 TDi….
Anyone recommend which make is better / longevity / price?
Any advice would be brilliant as I would prefer not to do the job twice! - Will also be fitting a set of H&R Lowering Springs at the same time <30mm
Many Thanks  :smiley:
Re: ** Best 'Top Mount' Advice Needed - Jetta / Mk5 **
« Reply #1 on: January 29, 2019, 07:25:48 pm »
i put oem ones back on when i did mine
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #2 on: January 29, 2019, 07:37:18 pm »
Just for comparison VW top mounts are £31 each + vat and bearings are £16 each + vat.
Offline muff1991
  • -Receive: 69
« Reply #3 on: January 29, 2019, 08:32:22 pm »
I thought the top mount and bearing is one piece? No?
Offline XxMK5xX
« Reply #4 on: January 29, 2019, 09:21:51 pm »
Do you think then go for VW ones? or OE? - Is there a lot of difference in quality / price?
Thanks Again
Offline muff1991
  • -Receive: 69
« Reply #5 on: January 30, 2019, 09:15:50 am »
if you can afford VW (go TPS tho) then probably best to go with that, if not an OE quality part will still do the job good fine. see how your pockets feeling after recovering from xmas ;-P
Offline XxMK5xX
« Reply #6 on: January 30, 2019, 10:16:46 am »
Think my TPS will not sell to the public - do you think there is a lot of difference between TPS and VW in price?
 :scared:
« Reply #7 on: January 30, 2019, 11:05:07 am »
You want TT ones as they are heavier duty than GTI ones.
Offline XxMK5xX
« Reply #8 on: January 30, 2019, 11:11:24 am »
Are they the same fitment? & bearings the same?
What is the price difference?..... Any part numbers would be brilliant!
Thanks Again
« Reply #9 on: January 30, 2019, 11:36:39 am »
Yep.  It's just the rubber part that's different.  A stiffer compound to suit the TT/S3's stiffer dampers.
Try searching for "TTRS/RS3 topmounts" as it's been discussed a million times.
Offline XxMK5xX
« Reply #10 on: March 15, 2019, 11:52:29 am »
Due to budget being a bit tight - 'if' I go with OE - What would be the best bet?!  :scared:
SKF
Sachs
Lemforder
Bilstein
Febi
'Other'
Is it worth changing any of the bolts too?
Thanks Again  :happy2:
« Reply #11 on: March 15, 2019, 12:21:39 pm »
Dealer ones in all honesty.  You only want to do the job once  :happy2:
As previously discussed, you'd be better off with the TT ones.  MK5 ones are a bit squidgy!
You will need to replace the strut mount bolts x 6 and also the strut pinch bolts x 2.  All of the chassis bolts (apart from the caliper carriers) are the use once variety unfortunately.
Offline XxMK5xX
« Reply #12 on: March 15, 2019, 12:34:24 pm »
Thank you, Looks like I will have to go for genuine, don't wanna do the job again!
Anyone know the correct 'Part Numbers'?
« Reply #13 on: March 19, 2019, 03:31:02 pm »
AKS sell the complete kit - https://www.akstuning.co.uk/top-mounts/562-genuine-ttrs-top-mounts.html
When fitting new top mounts, remember there is a correct orientation to use.  There should be a little nub on the rubber part that faces inboard or something.  Google it as I can't remember......even though I've done them about 3 times now  :grin:
« Last Edit: March 19, 2019, 03:32:42 pm by Pudding »
Offline Octoparrot
  • -Receive: 102
« Reply #14 on: March 19, 2019, 06:55:06 pm »
The OEM ones have an arrow that should point to the front of the car if I remember correctly.
