Author Topic: VCDS needed to retrofit xenons?  (Read 1565 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« on: January 30, 2019, 03:57:08 pm »
Hi, I have kufatec adaptors and complete xenons that I want to retrofit to my GTI.
If I'm not wiring up the shutter do I still need VCDS to get the xenons working once fitted?
Offline coolhandluke
  • -Given: 28
Re: VCDS needed to retrofit xenons?
« Reply #1 on: January 30, 2019, 04:34:40 pm »
Yes or it will be "disco time"  :P
Offline shoaybmakda
  • -Receive: 54
« Reply #2 on: January 30, 2019, 08:26:16 pm »
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #3 on: January 30, 2019, 09:40:36 pm »
Need to code it as xenons installed without shutters otherwise you’ll get error on dash
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #4 on: January 31, 2019, 05:42:17 pm »
Not only error, but the xenons will flicker like all's hell. Like @coolhandluke says - "disco time"!  :pomppomp:
Offline Usual Suspect
« Reply #5 on: February 01, 2019, 09:25:45 pm »
If you need them coded give me a pm
Offline Pashka
« Reply #6 on: February 02, 2019, 01:05:14 pm »
Shutters control can be taken from high beam, but everybody is is wiring up it to CECM  :thinking: :signLOL:
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
  • -Given: 28
« Reply #7 on: February 02, 2019, 03:14:48 pm »
Interesting , so can you enlighten us more?
