Author Topic: Turbo inlet diamter  (Read 2622 times)
Offline Beanmk5
Turbo inlet diamter
« on: February 03, 2019, 07:17:48 pm »
Hi I'm new to the forum so hi to all
I'm not totally clued up with modifying cars but eager to learn
I am going to get my car remapped but 1st I'm going to install a k&n typhoon induction kit
I got the kit off my friend cheap but unfortunately I'm missing the silicone part that connects the induction pipe to the turbo inlet
So question is I want to know the diameter of the pipe on the turbo so I can buy correct size silicone reducer, the induction pipe is about 70mm so needing to know if I need a reducer or straight pipe to mate the two together
I don't want to strip it down to get to the pipe to have to put it all back together again as need the silicone pipe
Thanks in advance
Offline muff1991
  • -Receive: 69
Re: Turbo inlet diamter
« Reply #1 on: February 04, 2019, 10:18:09 am »
not a direct answer, sorry.. but if it helps, I have the ram air induction kit.. and my induction hard pipe is also 70mm.. i remember measuring when I was buying an end cap to fit inside the silicone pipe (to make a boost leak tester).
I can assure you, the silicone pipe you'll need will not be a straight diameter pipe, the turbo inlet is definitely smaller than the induction kit pipe so yes you will need a silicone reducer pipe. as for the size of inlet, sorry I cant help.
Offline Beanmk5
« Reply #2 on: February 04, 2019, 11:26:23 am »
Thanks for that info mate
I'm thinking it's 2.5" but would like it confirming for definite, I've been told 2.5 but lad wasn't 100%
Offline muff1991
  • -Receive: 69
« Reply #3 on: February 04, 2019, 02:48:08 pm »
if I had to take a guess, I would of said 2.5"
just messaged my cousin, asking him to measure his old K03 inlet.. if and when he gets back to me i'll post up for ya :)
Offline muff1991
  • -Receive: 69
« Reply #4 on: February 04, 2019, 02:54:00 pm »
he just came back to me... said the internal diameter is 62mm so pretty much 2.5" is correct.. that's the size reducer you'll need :)
Offline Beanmk5
« Reply #5 on: February 04, 2019, 03:43:55 pm »
Thanks very much mate I appreciate that
Offline muff1991
  • -Receive: 69
« Reply #6 on: February 04, 2019, 10:00:32 pm »
Welcome mate, hope it helps
