Author Topic: 36mm oil filter socket  (Read 1389 times)
Offline Lewo
« on: February 06, 2019, 10:20:17 am »
The cheap low profile ones on Ebay ok?
Ta
Offline neilw
Re: 36mm oil filter socket
« Reply #1 on: February 06, 2019, 12:45:01 pm »
Should be fine, its only got to undo a plastic housing which should be pretty loose.
Edition30 #0002 R-Tech Stage2
Offline Chesto18
« Reply #2 on: February 06, 2019, 01:54:12 pm »
Halfords stock them. IIRC wasn’t much more than the cheap eBay ones.
Offline muff1991
  • -Receive: 69
« Reply #3 on: February 06, 2019, 02:17:15 pm »
I brought the cheap ebay one x amount of years ago.. done the job on my last GTI no problem! the oil filter housing is like 7nm of torque or sumin, so not tight at all.. if you're feeling manly enough you could probably hand wrench it haha!
Answer: the low profile socket from ebay will do the job perfect! :happy2:
Offline Lewo
« Reply #4 on: February 06, 2019, 03:46:03 pm »
Cheers all, will try Halfords tomorrow if no luck then Ebay.
