Author Topic: how to change cat back/back box on gttdi for a gti one (for twin tailpipe looks)  (Read 13826 times)
Offline Mandy
  • -Given: 95
  • -Receive: 94
Have twin discrete tailpipes on my gt tdi, wanting to change cat back/ back box for a gti/ ed30 one so i can have the twin tailpipes coming out.
I have brought a gti rear valance already...
What is it that i need to change?? I dont know much at all, lol! Is it the cat back or back box? whats the difference!
Any help much appreciated, feel free to laugh at me too, i dont mind!
Offline MattPoss
I bought a Cat Back Milltek system for my GT-TDI. Got it from Awesome with a rear valance which came to £416 delivered.
You can get a Resonated or Non Resonated system, Resonated inculdes an extra silencer where the Non Resonated doesn't.
I think i've also read about people fitting the back box from a 170bhp TDI and using a reducer clamp. Have a search around, might be able to find something about this.
Matt
Offline Howardvwgolf
take a look in the wanted section in the thread you started, found something on ebay you might be interested in
Offline Mandy
  • -Given: 95
  • -Receive: 94
Matt
Yes i think i read this somewhere too, on another forum. Did briefly look into a Milltek resonated cat back but about £400 like you said! I'll happily settle for a used gti exhaust or similar for under £100.
So did you go for resonated or non resonated? What's it like?
Offline B3n
  • -Receive: 29
  • Boom!!!!
To change to the twin exhaust easiest option is to get a 170 back box part no:v1k6253609bh for around £120.
You then need to cut your the pipe on exhaust that is currently on your car just before it reaches the back box you will see on the 170 back box where this needs to be done but leave a little extra on the pipe on the car to allow it to slide into the back box pipe. Then its a simple case of cutting 2 v shaped pieces out of the pipe on the 170 box slide this over the existing pipe add a little exhaust paste and clamp the pipe down onto the pipe on the car you dont need an adapter.
Im not the best at explaining things but anygood exhaust centre will no what to do its a 5 min job max.
Ill try and get some pics of mine up today.
This link may help
http://uk-mkivs.net/forums/t/171534.aspx?PageIndex=1
« Last Edit: February 22, 2010, 10:48:17 am by B3n »
Offline Mandy
  • -Given: 95
  • -Receive: 94
Thanks Ben  :happy2:
I did look into getting the 170 back box from vw, think it was just under £200. Tried to look around for a cheap used one and came across the Ed30 exhaust on here instead so I got that.
Do you know if it will fit on my gt in the same way as you describe??
Those pics look good, like the way only top half of the valance is coloured...
Offline B3n
  • -Receive: 29
  • Boom!!!!
Yeah i belive its more or less the same with the ED30 exhaust but im not sure the whole sytem is needed just the back box but if you got the whole system keep the centre section and stick it on ebay etc. Yeah it makes a drastic difference to the look of the car especially if you leave the centre section black it breaks it up a bit. Have you found a exhaust centre to fit it yet?
Ben
Offline Mandy
  • -Given: 95
  • -Receive: 94
Exhaust should either come tomorrow or day after i think...
Havent really thought about anywhere to get it done but i know someone who works in a garage who may be able to do it.
On the link that you provided earlier, i see they were saying something about needing the gti arch liners? Did you have this problem at all?
Also, the gti valance i got is the rough one, not the smoothed one so dont know whether i should smooth it down, or try to shall i say!  :signLOL:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
The valance you have will be the ''standard'' GTI one.The ''smooth'' one is from the edition 30 which is a lot more.  :happy2:
Offline Mandy
  • -Given: 95
  • -Receive: 94
Oh I see... Never thought that! I knew the smooth one cost about 10x more so just opted for the other one...
Offline B3n
  • -Receive: 29
  • Boom!!!!
Yeah stick to the GTI valance and get a bodyshop to do it should cast you around £100 smoothed and sprayed which is still £200 cheaper than the ED30 part.
Ideally you need the GTi liners as the gti bumper is a little wider at the bottom so you will have about 1cm gap at the very bottom. I didnt bother changing mine but if you are fussy i belive the gti liners are around £20 each.
Ben
Offline Mandy
  • -Given: 95
  • -Receive: 94
I've (and my bf)  just spent the best part of today trying to smooth the bumper down, still not as smooth as I'd like yet but getting there!
I think I'll prob whack the bumper on and see what it's like before deciding on the arch liners...
Ben, don't suppose you got any pics of yours just so i can get an idea of how it'll look?
Offline B3n
  • -Receive: 29
  • Boom!!!!
Good luck smoothing it all down its not as easy as sanding your nails isit :signLOL:
Ill get some pics taken tomorrow i was going to get some for you today but i left my camera lead in my house so ill take some in the morning for you.
Ben
Offline Mandy
  • -Given: 95
  • -Receive: 94
Well it's slightly harder than i first imagined (nothing like filing nails!) but i'm sure it'll be ok in the end  :confused:
If all else fails then I'll take it down the garage for them to finish it off before they spray it.
I thought about takin some before n after pics of the car but the weather is poo at the mo.
Look forward to seeing your pics!
Offline B3n
  • -Receive: 29
  • Boom!!!!
Before and after pics are a must just get your coat on and get out and take some.
Here are the pics of the arch liners on my car excuse the pics a pro i am not :wink:
And here are 2 of the exhaust connection
Before
After
Ben
« Last Edit: February 24, 2010, 10:46:32 am by B3n »
