Author Topic: Tailgate Damper / Strut Failure  (Read 1671 times)
Offline Juliand
« on: February 15, 2019, 02:33:25 pm »
Driver's side damper has given up, and need a replacement (tailgate tried to close on my head - and the lock bit is bl**dy sharp! :mad:).... Neither VW parts, or TPS have called me back, so I'm thinking e bay - can see a pair for about £14, but is this too cheap and nasty? Any suggestions appreciated, please...
Offline Juliand
Re: Tailgate Damper / Strut Failure
« Reply #1 on: February 15, 2019, 02:42:52 pm »
Update... Finally got through to TPS.....£52.30 for each side......'kin 'ell, for a small strut...... :surprised:
Offline richtung
  • -Receive: 56
« Reply #2 on: February 15, 2019, 03:08:12 pm »
you could try Euro car parts?
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2008/p/car-parts/body-shop/car-body-parts-and-car-exhaust/bonnet-strut-and-tailgate-strut/?859440951&1&0e2315399610722d14175d1149612d02794d9e78&001429
These should fit yours - just double check with the reg checker. Normally cost £21.99 but use discount Code "love51" and brings it down to £15.17
Hope this helps.
Rich
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #3 on: February 15, 2019, 03:32:06 pm »
I bought some Magnetti Marelli branded ones for my MK4, £20 odd for the pair.  Didn't have any problems with them.  Easy to fit, so even if they don't last it's cheap and easy enough to re-do. Better than over £100!
Offline Skel186
« Reply #4 on: February 15, 2019, 05:46:00 pm »
I bought some from these guys for my Citroen C4. Very good and they even knew the difference between tailgate with or without spoiler.
https://www.sgs-engineering.com/car-boot-tailgate/volkswagen
I've also bought a low entry jack from them and was impressed with the quality of that as well.
« Reply #5 on: February 15, 2019, 06:09:49 pm »
Those ones rust and wear out a lot quicker than the oem ones.
Offline Juliand
« Reply #6 on: February 27, 2019, 09:12:37 am »
UPDATE>>>>>
Thanks for all of the comments.
I took a chance on the ebay ones - £14 for a pair - it's not like it's a structural part. Comparing the replacement with the OEM, when I opened the box, I thought 'these don't look the same at all', with a much slimmer damping tube, so I just replaced the one that had failed, and crikey, the tailgate virtually opens itself, ha ha.  It's early days, so we'll have to see how it goes. It does look a bit strange with one very slim, against the chunkier VW original on the other side, but who the heck looks at that when opening up the boot - and I've got the other one to put on if it bothers me that much.  Been on a couple of days now, and I'm a bit nervous when getting stuff in / out of the boot, in case the tailgate crashes down on my head, but that's probably a bit paranoid, ha ha :grin:
Very easy to install too - a doddle. These were from Struts Depot - see how it goes.....
