Author Topic: DSG Swap  (Read 1647 times)
Offline chattvw
DSG Swap
« on: February 18, 2019, 01:24:11 am »
Will a DSG transmission interchange into another car with a different transmission code but same engine code?  For instance will a DSG from a 2013 GTI with a 2.0 TSI fit into a 2010 MK5 Jetta with a 2.0 TSI?
Offline Alex Booth
  • AKS Tuning
    • AKS Tuning
Re: DSG Swap
« Reply #1 on: February 18, 2019, 09:16:42 am »
It will, providing it has the original mechatronics with it. And may also need coding afterwards.
Offline chattvw
Re: DSG Swap
« Reply #2 on: February 18, 2019, 07:39:10 pm »
This is good to hear, yes the transmission is complete with the mech unit.  should I change the coding to match what the original mech unit coding is from the 2010?
Offline Alex Booth
  • AKS Tuning
    • AKS Tuning
Re: DSG Swap
« Reply #3 on: February 19, 2019, 09:44:29 am »
Should be plug & play to be honest. I would fit and see how it goes, may need some slight adjustment but typically they are spot on by just swapping them out.
Offline chattvw
Re: DSG Swap
« Reply #4 on: February 19, 2019, 02:50:20 pm »
this is interesting, do you know anyone that has done a swap like this with miss-matched transmission codes?  I've seen several manual to DSG swaps which is similar because there was no DSG transmission code allocated to those cars.
