Author Topic: Gauge Recommendations  (Read 5207 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« on: March 06, 2019, 01:31:16 pm »
Hi, i'm looking to add some gauges, coolant & oil temp and oil pressure.
Anyone recommend some decent gauges or ones to stay away from?
Offline absolute
Re: Gauge Recommendations
« Reply #1 on: March 06, 2019, 01:31:45 pm »
Why not Polar FIS?  :wink:
Edition 30 #1994 now sold. *cries*
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #2 on: March 06, 2019, 02:45:40 pm »
That does seem quite handy but previously I've had gauges and thought they were really easy to read and they do look nice.
Offline absolute
« Reply #3 on: March 06, 2019, 04:39:22 pm »
Hello there
Yes, if you like the gauge look then Polar FIS won't offer that!
Offline Octoparrot
  • -Receive: 102
« Reply #4 on: March 06, 2019, 05:52:18 pm »
You should already have a coolant gauge.  :thinking:
Offline f00glee
« Reply #5 on: March 07, 2019, 08:33:21 am »
I'm not clued up with polar FIS. Does it require both high-line cluster and multi function steering wheel? Or just the cluster and control via wiper stalk buttons?
I'd briefly looked for an OBD gauge solution and stumbled across the "P3" gauges - obd based with a small screen integrated into the original air vent on the right hand side of the dash. Bloomin' expensive though, especially for something not as nicely integrated as the polar option seems to be.
Current:
Mk6 R, Tornado Red, 5-door, '13.
Previous:
Mk5 GTI, Tornado Red, 3-door, '06, R-tech Stage "1+"
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #6 on: March 07, 2019, 09:40:06 am »
I'm sure I read that the stock coolant gauge wasn't accurate.
« Reply #7 on: March 07, 2019, 12:11:38 pm »
Just the Highline cluster.  A ball ache to fit.  It basically replaces the factory CAN-BUS box, which to get at, necessitates removal of the wiper mechanism to get at the access panel on the scuttle panel.   Some people claim to be able to get at it from underneath inside the car, but they must be contortionists with tiny hands.
I sold my Polar FIS shortly after getting it.  The main reason was the highline display is too laggy to keep up, especially when cold.  Trying to watch boost and lambda activity was too blurry.  The display was never designed for that refresh rate in mind.  An analogue gauge is way easier to read,  but gauges clutter up the cabin and take your focus away from driving.
I like those P3 gauges but as you say, big bucks.  I'm not convinced they would survive the extremes of hot and cold from the HVAC system for long either.
