Author Topic: ** Front Rear Wishbone Bushes MK5 Jetta **  (Read 6325 times)
Offline XxMK5xX
« on: March 15, 2019, 11:57:42 am »
Hiya,
Anyone changed the front rear wishbone bushes with 'powerflex'?
Is it a easy job?, Benefits?
I not 'powerflex', anyone used any other?
Cheers  :popcornsoda:
Offline colesey
  • -Receive: 89
Re: ** Front Rear Wishbone Bushes MK5 Jetta **
« Reply #1 on: March 15, 2019, 11:59:23 am »
Powerflex might be a good choice as the Superpro alk I had fitted did not change the castor from stock.
« Reply #2 on: March 15, 2019, 12:24:39 pm »
Might be cheaper to press in S3 bushes to your existing console housings.  You shouldn't need an alignment afterwards either as long as everything goes back they way it came off.  They're an uprated version of the MK5 bush.  Darkside Developments sell them  :happy2:
You will need to replace every bolt that comes off I'm afraid.  Gets expensive.
Offline XxMK5xX
« Reply #3 on: March 15, 2019, 01:26:36 pm »
I will have a look on darkside  :happy2:, where is the best place for the 'bolts' - VW?
Thanks Again
Offline chigmuss
« Reply #4 on: March 16, 2019, 07:18:49 am »
Vagbolts on ebay are reasonably priced
Offline colesey
  • -Receive: 89
« Reply #5 on: March 16, 2019, 07:42:32 am »
+1. Great service from Gavin also.
