Author Topic: Suspension refurb the whole lot  (Read 6374 times)
Dave Y
« on: March 15, 2019, 12:48:38 pm »
i am looking to refurb all bushes ,shock absorbers and fit uprated Eibach arbs.
i want to stay with standard bushes and shocks or as near as as possible.
where can i get a good deal ?
what make bushes are close to standard?
All advice welcome, i dont want the ride to be too harsh.
Offline colesey
  • -Receive: 89
Re: Suspension refurb the whole lot
« Reply #1 on: March 15, 2019, 02:01:32 pm »
I have the racingline suspension kit / H&R small arbs / Superpro's road durometer polybush front arm kit and the ride is still pretty decent whilst improving handling no end. I did however avoid the rear bushes due both to the high labour costs and also fear of road noise getting amplified through boot.
Dave Y
« Reply #2 on: March 15, 2019, 02:43:15 pm »
i would like to replace every bush with oem or the equivilent.
Offline chigmuss
« Reply #3 on: March 16, 2019, 07:17:29 am »
I went Febi-Bilstein on most of the stuff I replaced but had to flit between ebay ecp and Eurodoc for the best deal on some.
For your tops mounts the scuttle panel needs dis-assembled to get to the three bolts which are a t**t to get off. Mine span as the rubber was gone that they're cast into. Make sure you mark your wiper arm position as it's a pain of trial and error otherwise when re-fitting.
Dave Y
« Reply #4 on: March 16, 2019, 07:58:00 am »
Will do ,thanks
Offline El1M1N8OR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2c58fkdv8a7mdci2je24i8j2g3&/topic,127700.msg1139562.html#msg1139562
« Reply #5 on: March 17, 2019, 12:23:42 pm »
I am thinking about upgrading my suspension.
Is it adviseable to upgrade all the bushes with the kit?  I was under the impression the kit was all that was required for the upgrade.
Dave Y
« Reply #6 on: March 17, 2019, 06:50:14 pm »
I have been trying to find a diagram showing all the bushes but no luck.
Offline muff1991
  • -Receive: 69
« Reply #7 on: March 18, 2019, 07:40:12 am »
There is a bush diagram on powerflex website?
Dave Y
« Reply #8 on: March 18, 2019, 09:10:48 am »
Ok thanks
