Author Topic: Oil pump ??  (Read 5123 times)
Dave Y
Oil pump ??
« on: March 17, 2019, 05:16:12 pm »
Is it a weak link ?
How many miles are they good for?
Are they expensive?
Is it major surgery to fit ?
Offline probedb
Re: Oil pump ??
« Reply #1 on: March 17, 2019, 07:31:34 pm »
New you're looking at about £1300 I believe from the quote I got from my garage. Mine failed and ultimately caused an engine failure. But I'm not lucky with cars :D
Dave Y
Re: Oil pump ??
« Reply #2 on: March 17, 2019, 07:55:34 pm »
Oh dear .
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Oil pump ??
« Reply #3 on: March 17, 2019, 09:51:15 pm »
Was advised by a mechanic, who did some work on my car to get oil pump done as it was high milage, they do fail but when is the game of Russian roulette
Mine was done two weeks ago at 120,000 miles on bkd engine
New fai pump cost me £76.  Had to get tube of sump gasket seal too
Mechanic didn't charge me any extra, as was swapping head and gasket to revision C, my old head B was porus.   Was a long day.  It's a relief to know it's brand new.
« Last Edit: March 17, 2019, 09:53:16 pm by ady-uk »
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Dave Y
Re: Oil pump ??
« Reply #4 on: March 17, 2019, 10:09:08 pm »
Where did you buy the pump from??
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Offline GVK
  • -Receive: 68
    • GVKmotorsport
Re: Oil pump ??
« Reply #6 on: March 17, 2019, 10:53:41 pm »
Dave, BKD is a diesel.
You have an Ed 30 right?
Dave Y
Re: Oil pump ??
« Reply #7 on: March 18, 2019, 12:24:04 am »
Yes, edition 30
Re: Oil pump ??
« Reply #8 on: March 18, 2019, 05:05:53 pm »
The oil pump and balance shaft assembly are one unit, hence the price.
'The internet' says it's a common failure (as it always does about everything) but there isn't enough hard, unequivocal data to back it up.
The only acknowledgement from VW was a recall on VERY VERY early EA113 engines because the balance shaft sprocket liked to fall off.  I think they changed the nut/washer on it or something.
The only community speculation on it is servicing regime (oil change frequency, oil quality, oil level) and tuners extending the rev limit past 7500rpm, which over spins the balance shaft.  I think the shafts just run in plain line bores like the cams, so any excessive heat won't be welcomed.
Take from that what you will, but there's no point replacing a £1000 part just because it might break.
