Author Topic: Advice needed.  (Read 4562 times)
Dave Y
Advice needed.
« on: March 21, 2019, 02:23:08 pm »
My car has done just over the 100,000 miles.
Would it be advisable to have the oil pickup pipe renewed and the inlet manifold cleaned.
Or am I getting confused??
Re: Advice needed.
« Reply #1 on: March 21, 2019, 02:55:09 pm »
Definitely worth doing the oil pickup for preventative maintenance.  The carbon cleaning isn't so much of a big deal.
Dave Y
Re: Advice needed.
« Reply #2 on: March 21, 2019, 07:25:57 pm »
Ok thanks .
Do I buy a new pipe ?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Advice needed.
« Reply #3 on: March 21, 2019, 07:38:14 pm »
I bought a new pipe. You also clean the sump out whilst  it's off.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Advice needed.
« Reply #4 on: March 22, 2019, 09:59:08 am »
Some clean and re-use - but for the cost of the pickup, seal and sealant, do it once and do it properly. Regular (non longlife) oil changes from then on will mean its a one off exercise
Dave Y
Re: Advice needed.
« Reply #5 on: March 22, 2019, 05:12:20 pm »
Just spoken to Gwent VW on Leeway ind Estate
oil pickup pipe  + seal
oil system cleaner
oil filter + oil.
new sump plug
sump sealant
£350 inc vat.
Does that sound about right?
Offline Dogma
Re: Advice needed.
« Reply #6 on: March 23, 2019, 09:10:32 am »
oil system cleaner
oil filter + oil.
new sump plug
sump sealant
£350 inc vat.
For VW yes
MK5 ED30
Dave Y
Re: Advice needed.
« Reply #7 on: March 23, 2019, 09:24:52 am »
It’s not actually a VW dealer.
Offline Dogma
Re: Advice needed.
« Reply #8 on: March 23, 2019, 10:52:32 am »
Okay sorry you should of said VW specialist.
MK5 ED30
Dave Y
Re: Advice needed.
« Reply #9 on: March 23, 2019, 10:59:09 am »
That is what they are called.........Gwent VW
Re: Advice needed.
« Reply #10 on: March 23, 2019, 10:59:56 am »
What is 'oil system cleaner' ?   If that means engine flushing, I would steer clear of that personally.
£350 seems a bit steep.  It's a dead easy job DIY and the tube and sealant are cheap enough.  In this day and age I prefer to do that sort of thing myself to ensure it's done properly and most cost effectively.
Dave Y
Re: Advice needed.
« Reply #11 on: March 23, 2019, 11:55:19 am »
I think i will be going to Turner performance and not bother with the engine flush.
VW Gwent said i would need a new sump plug also ???
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Advice needed.
« Reply #12 on: March 23, 2019, 12:20:31 pm »
It's  more the washer for the plug
Offline Octoparrot
  • -Receive: 102
Re: Advice needed.
« Reply #13 on: March 23, 2019, 09:51:41 pm »
The washer is fixed to the plug hence you're meant to change the plug every time you removed it, should be plenty for sale on eBay.
Re: Advice needed.
« Reply #14 on: March 29, 2019, 10:04:58 am »
The sump plug is classic up sell.  I've reused the same one on the last 5 or 6 oil changes and it doesn't leak.
