Author Topic: Subwoofer Wiring  (Read 1504 times)
Offline E8RNX
Subwoofer Wiring
« on: March 25, 2019, 03:22:49 pm »
Hi guys so I’ve got a head unit ordered which is on the way as well as a new can gateway. I already have a sub in the garage and wiring etc but wanted to ask if any of you guys have fitted a sub in too?
I wanted to know which route from the engine is best to wire the power cable through? I’ve heard there’s one behind the battery box. Would be great if you guys could share your setup to help me do mine most likely this weekend.
—MK5 Golf GTI DSG—
Offline Shamm
Re: Subwoofer Wiring
« Reply #1 on: April 01, 2019, 11:54:33 am »
Yes behind the battery there is a grommet which leads you to behind the glove box but be careful when your piercing through the grommet that you dont cut another wire
Offline E8RNX
« Reply #2 on: April 01, 2019, 11:43:52 pm »
Cheers for that  :happy2:
I found a gromet behind the battery box like you said and wired the sub power wire through there. Also put in a new headunit :)
—MK5 Golf GTI DSG—
Offline The Red Warrior
« Reply #3 on: April 04, 2019, 11:58:43 am »
Did you wire directly to the battery (with an in-line fuse) or did you connect to the bus bar?
Offline E8RNX
« Reply #4 on: April 04, 2019, 12:54:57 pm »
Directly to the battery mate with a fuse of course :). Fuse placed inside battery box so stays out of the way too  :happy2:
—MK5 Golf GTI DSG—
