Author Topic: Car cut out  (Read 1620 times)
Offline AlexRennieGti
Car cut out
« on: March 26, 2019, 09:14:42 pm »
Hey guys driving home tonight and my car cut out. No warning lights or anything. Tried too start it again and it seemed as if the battery was dying. But after a few turns of the key it started and ran fine.
Anyone got any ideas ?
Offline Alex Booth
  • AKS Tuning
    • AKS Tuning
Re: Car cut out
« Reply #1 on: March 27, 2019, 03:02:00 pm »
Do you have access to VCDS? Could be a number of things.
Re: Car cut out
« Reply #2 on: March 27, 2019, 03:50:02 pm »
Yes I do. Done a quick scan and no faults shown up
Offline muff1991
  • -Receive: 69
Re: Car cut out
« Reply #3 on: March 27, 2019, 04:25:57 pm »
have you had any work done recently? put a multi meter on your battery before starting then again once started.. see what volts you're getting.
has the car started and drove fine today?
Re: Car cut out
« Reply #4 on: March 27, 2019, 07:40:55 pm »
Before starting voltage was 11.5v and once running voltage was between 13.9-14.3v
The car smells like it’s over fueling can smell petrol
Re: Car cut out
« Reply #5 on: March 29, 2019, 01:23:04 pm »
Cut out under what circumstance?  Driving along normally, or when pulling up to a junction/roundabout?
11.5V is too low.  Should be around 12.6 with the engine off, so you'll be needing a new battery at some point.
Re: Car cut out
« Reply #6 on: March 31, 2019, 08:07:50 pm »
I would honestly be better with a new car. More problems today.
While driving getting random puffs of smoke from exhaust not constant and get low oil pressure flashing up flashes like once or twice and goes off.
Offline muff1991
  • -Receive: 69
Re: Car cut out
« Reply #7 on: April 01, 2019, 08:58:51 am »
maybe it could be the Oil Pick Up Pipe in the sump?
Re: Car cut out
« Reply #8 on: April 01, 2019, 11:06:18 am »
Would that cause the odd puff of smoke but ?
Offline muff1991
  • -Receive: 69
Re: Car cut out
« Reply #9 on: April 01, 2019, 03:20:00 pm »
not sure if it would be the cause of smoke but it could be the cause of the low oil pressure
