Author Topic: Wipers  (Read 3607 times)
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Wipers
« on: February 18, 2010, 02:00:59 pm »
Ever since I got my Golf the wipers have settled in the off position when I turn the engine off. Now they are settling in the fully up position when I turn my engine off.
Any ideas why?
Offline t20lau
    • Website design Sheffield
Re: Wipers
« Reply #1 on: February 18, 2010, 02:12:03 pm »
Would be good to know the answer to this...I think mines doing the same!
SEAT Ibiza Sport | Vauxhall Astra VXR | BMW Z4 M-Sport | VW Golf GTi Edition 30 | BMW F30 330D X-Drive
Re: Wipers
« Reply #2 on: February 18, 2010, 03:01:22 pm »
they were turned on by the polo down the road?  :popcornsoda:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Wipers
« Reply #3 on: February 18, 2010, 03:07:35 pm »
They will 'turn' themselves so a different edge is resting on the glass each time you stop the engine.  Its a little trick to prolong the life of the blades apparantly...
Sepang Blue S4 BE Avant
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Wipers
« Reply #4 on: February 18, 2010, 07:31:57 pm »
Any ideas why?
.......isin't that the ''service'' position ?. Done when you press the wiper arm once just afturning the ignition off?.
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Wipers
« Reply #5 on: February 18, 2010, 09:55:11 pm »
^^  Oh yeah.  What he said.
I thought we were talking about the little twitch they do when you turn the engine off...
Offline scotta
  • Edition 30
Re: Wipers
« Reply #6 on: February 18, 2010, 10:02:16 pm »
Ahhh right - i did wonder about that!! what a clever little golfy! 8)
Re: Wipers
« Reply #7 on: February 18, 2010, 10:21:23 pm »
 :laugh:
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: Wipers
« Reply #8 on: February 24, 2010, 01:59:29 pm »
Its also for use in cold weather so you can remove the wipers from the windscreen to stop them freezing on, in case you have a trip to the alps planned :smiley:
  • -Given: 32
  • -Receive: 78
Re: Wipers
« Reply #9 on: February 24, 2010, 02:15:38 pm »
I may have not described the problem correctly. They are sitting vertically when I turn the engine off. It may be that it's the service position thing mentioned earlier.
Offline FamilyDub
  • ...who needs a diesel?
Re: Wipers
« Reply #10 on: February 24, 2010, 02:39:19 pm »
^^^ Yes.
You mean the blade sits like this   -->   |
Instead of  like this?    -->                 ---
Unless you are pulling the wiper stalk, then it sounds like an electrical gremlin. Try changing the fuse?
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
Offline scotta
  • Edition 30
Re: Wipers
« Reply #11 on: February 24, 2010, 02:57:05 pm »
^^^ Yes.
If the fuse was gone they wouldnt work at all.
Offline FamilyDub
Re: Wipers
« Reply #12 on: February 24, 2010, 02:58:34 pm »
Oh aye!  :stupid:
Be fcuked if I know, then.
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: Wipers
« Reply #13 on: February 24, 2010, 03:09:54 pm »
Could it be some sort of Convenience menu function or programing for cold climates to always default into service position, allowing them to be removed form the windscreen?  I have no experience with VAGCOM, so this is just a suggestion.
