Author Topic: Airbag light deactivated MOT fail?  (Read 2121 times)
Offline hussnainh8
« on: April 03, 2019, 12:23:59 am »
Hi
Quick question.. I have deactivated the driver and passenger side airbags which when starting the car, flashes the airbag light and shows a "airbag deactivated" message on the display. My question is..  Is this an MOT failure or will the car still pass? Its not a fault in the system, the side airbags have been disabled because the car has been fitted with aftermarket recaros.
The car is an edition 30 2007. If this is a failure, is there any other way to get rid of the airbag light?
Thanks.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=09eseqas2tmm0aiipau8p36j3t&/topic,19740.0.html
Re: Airbag light deactivated MOT fail?
« Reply #1 on: April 03, 2019, 08:23:32 am »
Use resistors at the connectors.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: April 03, 2019, 08:48:57 am »
Its questionable. This is an extract from the manual - deactivated passenger airbag is not a fault with the system and if the dash does not confirm whether its passenger side or both sides then I think you could blag a pass. Me personally I would have resistors as that message on every start would annoy me.
Quote
7.1.5 Airbags
This inspection is for all airbags fitted as original equipment other than on Class 3 vehicles.
A passenger airbag that is switched off isn’t a defect.
Defect        Category
An airbag fitted as original equipment obviously missing      Major
An airbag obviously inoperative                                          Major
Offline hussnainh8
« Reply #3 on: April 03, 2019, 12:18:24 pm »
How much ohm resistor am I using? Says 2.2ohm or 3.7ohm?
Thanks.
