Author Topic: Tyre pressure sensors?  (Read 5563 times)
Offline probedb
« on: April 11, 2019, 12:16:25 pm »
Does anything need swapping on the wheels? I've got a set of 18" diamond cut monzas from a mk6 to go on and was wondering if I needed to move any sensors as I have the pressure warning button in my car?
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
Re: Tyre pressure sensors?
« Reply #1 on: April 11, 2019, 01:01:39 pm »
No
Offline probedb
« Reply #2 on: April 11, 2019, 01:16:03 pm »
Cheers !
Offline amanda
« Reply #3 on: April 11, 2019, 01:22:27 pm »
If you are selling your old wheels keep the valves as spares 😉
Offline probedb
« Reply #4 on: April 11, 2019, 01:32:10 pm »
Keeping the old 17s for winter  :smiley:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=97cal9nf2399qe0srminh5lc99&/topic,19740.0.html
« Reply #5 on: April 11, 2019, 01:44:36 pm »
There are no sensors for the mk5 tyre warning system. It uses the ABS sensors.
Offline probedb
« Reply #6 on: April 11, 2019, 02:18:04 pm »
Excellent, thanks very much, clears that up nicely :)
Offline amanda
« Reply #7 on: April 11, 2019, 02:45:20 pm »
Depends as mine have Tps sensors as an option
Offline probedb
« Reply #8 on: April 11, 2019, 02:56:58 pm »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9 on: April 12, 2019, 01:51:12 pm »
Golfs and other models of the same segment have a passive sensor system. There are no wheel sensors. It just uses the ABS sensors like rich83 said.
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #10 on: April 12, 2019, 05:10:36 pm »
My golf has tpms, with wheel sensors, and displays all type pressure in the clocks.
Quick video I did when installing discover media - TPMS display about 4:50 in
&t=10s
« Last Edit: April 12, 2019, 05:12:44 pm by ady-uk »
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
« Reply #11 on: April 12, 2019, 06:11:05 pm »
Good description here...
https://www.my-gti.com/321/volkswagen-tyre-pressure-monitoring-system-tpms
That's a lot of words to say a flat tyre has a different rolling circumference to a pumped up one  :grin:
It's useful on motorways if the light comes on so you can pull over before causing damage, otherwise it's not a lot of use as it doesn't tell you which tyre is flat.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #12 on: April 16, 2019, 02:20:06 pm »
&t=10s
I never said it was impossible to retrofit the active TPMS. :wink:
