Author Topic: Got a bit of a problem & need help  (Read 6760 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« on: February 19, 2010, 11:38:52 am »
Got these fault code below.
According to RossTech wiki for the first one it says
Possible Causes
Throttle Valve Control Module (J338) dirty/faulty
Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Possible Solutions
Check Throttle Valve Control Module (J338)
Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
1 Fault Found:
001287 - Idle Control System RPM: Higher than Expected.
               P0507 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 88289 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:12:48
             Freeze Frame:
                    RPM: 1174 /min
                    Load: 14.1 %
                    Speed: 0.0 km/h
                    Temperature: 88.0°C
                    Temperature: 44.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
Readiness: 0110 0100
Then a bit later got this fault
1 Fault Found:
008825 - Leak in Air Intake System
               P2279 - 002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 88294 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:30:47
             Freeze Frame:
                    RPM: 846 /min
                    Load: 14.1 %
                    Speed: 0.0 km/h
                    Temperature: 91.0°C
                    Temperature: 41.0°C
                    Voltage: 14.097 V
Nothing on RossTech wiki for that fault.
Basically the car is Idling very high (circa 1250-1500rpm)
The only thing i have done is put a new battery in it that i got from the VW dealer nearby so its the correct battery as was done by part no.
Couple of questions
Where are the
And where it says leak in the Air Intake system is that literally from the EVOMS to the Turbo or is it also including the route taken by the gases as they come out of the turbo to the Throttle body? (i.e turbo outlet, intercooler, intercooler piping and throttle body hose)
Help would be appreciated as car is due MOT in a few weeks and will no doubt fail if thats not fixed
Carl
Offline Janner_Sy
  • -Receive: 113
Re: Got a bit of a problem & need help
« Reply #1 on: February 19, 2010, 12:57:59 pm »
wonder if that first one will be the cause of your recent issues?? but has only just thrown a fault
« Reply #2 on: February 19, 2010, 01:02:50 pm »
Try this Carl.
http://wiki.ross-tech.com/index.php/Throttle_Body_Alignment_%28TBA%29
As it says make sure THE ENGINE IS NOT RUNNING!!!!!!
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: February 19, 2010, 01:12:43 pm »
Did all that Ian to no avail.
Any how Cancel my last
Turns out it was a small problem
I had a hole in this pipe. Just replaced it and all is well
Carl :happy2:
« Reply #4 on: February 19, 2010, 01:14:27 pm »
Nice one.  :happy2:
I would hate you to have any excuses for tomorrow.  :P
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: February 19, 2010, 01:59:46 pm »
Yeah god forbid :P
Carl :happy2:
« Reply #6 on: February 19, 2010, 02:02:45 pm »
Did you actually quantify what new battery, W8 light and sharks fin aerial will contribute in hp?  :laugh:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #7 on: February 19, 2010, 02:22:48 pm »
Well it will be around 50bhp & 60lb/ft for the Battery
20bhp and 30lb/ft per LED on the W8
The Shark fin reduces drag coefficient so will now hit 62 faster than a formula 1 car and out drag the Thrust SSC
Not bad really for about £150 :signLOL:
Oh and i seem to have been a bit premature on the signal quality of the Shark Fin
It seems as soon as i leave my drive it no longer works.
Going to ensure i connected it up properly then will have to take apart and see if i can swap gubbins over from old to new
Alternatively any idea if you can buy  a signal booster?
Carl :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: February 19, 2010, 04:12:08 pm »
I saw the title and wondered how it had taken you so long to realise  :P
Stu...
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #9 on: February 19, 2010, 05:09:23 pm »
The wedding is still going ahead mate  :signLOL:
Carl :happy2:
