Author Topic: R32 owner - anything I need to do  (Read 5701 times)
Offline stuartj9
« on: April 17, 2019, 11:34:51 pm »
I hope I'm not the black sheep of the family lol. I've had my R32 (56) MK5 for 2 months now. I love it! Anyway, I was wondering if there's anything I should have done on it to prolong it's life. It's had an oil and filter change It's on 111k miles now. Is there anything else I need to look out for?
TIA
Re: R32 owner - anything I need to do
« Reply #1 on: April 18, 2019, 08:27:30 am »
Plugs and haldex every 40k..clean all the  crap out from behind wheel trim..I have had mine detailed and the paint work ceramic coated
Offline stuartj9
« Reply #2 on: April 18, 2019, 06:21:57 pm »
Thanks Andy.. Haldex was done 10k ago with the plugs so another 30k to go ;)
Anything else guys?
« Reply #3 on: April 18, 2019, 06:33:51 pm »
Engine wise they are utter tanks apart from chain wear.  Unfortunately yours is on the 2005/2006 change over year for the revised chain gear.
Therefore I would buy VCDS and scan measuring blocks 208 and 209 and check the chain condition.  Outer wear limit is -8 to +8KW.  After that the ECU can no longer correlate the crank/cam position and will run in limp mode.
If you're anywhere near Suffolk, happy to scan it for you and look over the car.  I was a bit of an R32 guru back in the day  :smiley:
« Last Edit: April 18, 2019, 06:35:52 pm by Pudding »
Offline stuartj9
« Reply #4 on: April 18, 2019, 10:12:49 pm »
Pudding, you the man! Right, I have a VCDS (genuine) so will give it a scan tomorrow. Car feels great apart from a knock when turning (I've been told it's top mounts so nothing to worry about). Appreciate the offer of a scan though  :happy2: I will post my results tomorrow. No signs of limp mode on this lump. It's quick and a real pleasure to drive.
Would mine not have the newer chain? It's 56 so late 2006. It was actually 19 Sept 2006.
« Reply #5 on: April 19, 2019, 10:00:41 am »
If the chains are in tolerance then they will be fine..also the knock could be top mount or they are known for sub frame knock which you can fix with a kit..
Offline stuartj9
« Reply #6 on: April 19, 2019, 10:53:14 am »
Sub frame kit has been done  :happy2:
It's definitely the top mounts, as you rightly said. CV joints look fine.
« Reply #7 on: April 19, 2019, 12:30:03 pm »
2006 will probably have the newer chains, but worth checking those measuring blocks anyway.  Chains just wear out regardless!  Hopefully yours will be in the 0 to +3KW range which is spot on.
What subframe kit does it have?  The toothed washers from VAG is only a temporary solution.  Proper collars are needed to take up the (huge) difference in the bolt to hole diameter.
I've never heard a top mount knock unless severely worn.  The most common cause of front end knocking on these cars is either the steering rack or subframe movement.  If it just a top mount, happy days, put a pair of TT ones on as they are beefier.  If not....... get saving!
Offline stuartj9
« Reply #8 on: April 19, 2019, 04:12:13 pm »
I've used the toothed washers but to be honest, it hasn't made a difference. I think the subframe is fine.. for now.
The knock is a very slight tap on turning both ways. It's more annoying than anything.
Here's the 208 and 209 logs. All done with engine off (is this right?)
16:06:59 Group 208: Camshaft Adjustment Adaptation (Intake)
  0 /min  Engine Speed (G28)
  123  Phase Position Intake Cam.
  -5.0°KW  Intake Cam. Offset
  00100000  Intake Cam. Adaptation
16:06:59 Group 209: Camshaft Adjustment Adaptation (Exhaust)
  75  Phase Position Exhaust Cam.
  -3.0°KW  Exhaust Cam. Offset
  00100000  Exhaust Cam. Adaptation
« Reply #9 on: April 20, 2019, 04:50:42 pm »
5 and 3 is cool and the gang  :happy2:
Keep an eye on it.  When they start drifting towards +8KW, that's when they need changing.
If the knock/tap/click is only at very low speeds with lots of steering lock, it's subframe movement.  Usually clunks once and then is fine for the rest of the journey.
Offline stuartj9
« Reply #10 on: April 21, 2019, 10:24:28 pm »
The knock is a tapping when turning and it's say, 6 times per full lock at the same intervals, no clunk. It might happen at higher speeds but I don't hear it then.
